Clearcoat Missing on a 5 day old AW C7
Just picked up my C7 a few days ago.. Love the car... One problem.. There is a 3" Star Burst (best I can describe it) on the drivers side rear 1/4 panel near the gas tank. It looks like possible missing Clearcoat?? I tried to take a picture, see attached but its difficult to see from a photo... When I rub my finger over it, my finger GLIDES very fast over that area, but on the rest of the car there is resistance from the gloss/clearcoat... Any ideas what this could be?? Is it something the dealer might be able to repair? I will be calling them Monday.. Just need some advise! Has anyone else had this problem?
Thanks!
Thanks!
I have a new AW C7 and had a few spots that did not look right, but after a little detail the finish was perfect.
If you have any concern the paint is fully covered by your warranty.
It is most likely a gas stain or some other chemical that can be detailed off.
Just enjoy the car and don't worry, let the dealer do the worrying.
It's not Clear Coat failure.
The pic isn't clear, but it looks to be an area that has less Orange Peel since you said it is smooth.
Might have been a touch up done there.
But I agree with the other guy, take it to your Dealer if your concerned.
Depending on whats going on there some light wet sanding and buffing may do it. make sure they know what they're doing. Some dealers use outside shops for bodywork which is good. Talk directly to the people doing the work. Should be fine.
Maybe you can get them to wet sand any OP if there is any.
I had a few dull spots like that on my roof and hood. Kind of a mystery but we decided it must have been from the white shipping cover flapping in the breeze during its ride on the transport truck. There are certain positions on the truck that subject the covers to a lot of turbulence. The marks did buff out easily, they are just a memory now.
Received 19,209 Likes
'20-'21-'22-'23-'24
Good luck getting it fixed - a good shop should make it look great.
Thanks!
Thanks!
Looks like a stain from bird poop.
If it was bird poop, then it would have happened before I received the car. Shape is too circular on trunk fold. It's starting to look like a manufacturing suction cup mark to me as it seems to be right at the same spot as for IceMezzer.
I tried to take a photo this morning.
My friend is an artist with a buffer and volunteered to buff out the marks. Only took a few minutes, not sure of the products used. If it's just that one small spot I'd just use any good cleaner-wax and polish it out by hand
