C7 oil pressure
C7 oil pressure
What is considered normal oil pressure for the LT1. Mine seems to move around a lot and is usually less than 40psi going down the road after it is warmed up. Thanks in advance.
Mine is usually about 35 psi when cruising at 75 with a base A6. I think that’s pretty nominal from what I’ve heard from other posters.
When I’ve had it at higher rpms, I’ve been watching the road not the pressure readings. Don
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Higher viscosity = higher pressure for the same volume
I'm curious at what RPM range the new 2 stage regulated oil pump goes to the higher pressure setting.
My car has been at 4B00 for 5 days, and then I'll have the RPM restricted break in.
Does any one care to run a experiment for me? I'll say nice things about you, and tell you, "thanks."
Ed
Ed
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
According to this:
Anything from 36.7 to 47.7 on the gauge is normal when warmed up.
Elmer
Elmer
