Drivers side electronic seat issue
Does anyone know if there has been flash for the problem with the seat memory issue. I don't even have the memory set but yet my drivers seat on several instances will not move back from the position I have it when driving. I only use the button on the seat but I have heard that this relates to the seat memory issue. Of course there is no issue when the dealer looks at it and no codes so they are unable to do anything
Then when it's programmed, you can press the brake, don't depress the clutch and hit the accessory button and your seat will move into your preferred driving position. Search for seat memory problems and you'll find a ton of stuff.
Hope this helps.
