Ripples in doors?
Ripples in doors?
Maybe it's just me but I just came back from my local dealer, they had 8 cars 4 2014's and 4 2015's. As i looked down the sides of each car there was a significant mount of body ripple in each door? Not paint but body panel ripples or wavy if you will. Not one but all eight.
i dont recall this in late year C6s? does this improve over time (later years)? Can anyone comment on the C6 run and say when the doors lost the ripples?
C5 forum mentions it in early years also.
Am I seeing things? Is this a characteristic of the new body material, I dont see it in any aluminum door cars I've been cross shopping.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
I didn't find any ripple in my door but I did find a bottle of Thunderbird
Thats my question. If later years of the C6 dont have ripples I assume GM gets better at making these plastic panels. C5 went through the same thing. Does this get corrected in year three?
i'm not sure putting on rippled glasses is the answer here. So as of today all C7s have this feature?
Is looking the other way really what people do?
i've slowly been learning how to block sand and took on some painting projects. Only my own cars. i prep them prime and bring them to a friend with a professional spray booth.
I'm a beginner but I hate when i can see tiny ripples in my final product. then i saw it on the C7 and it makes my amateur work look great. Maybe I'm being too picky but the stamped aluminum panels are look razer straight to me.
Received 9,514 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
The C7 composite is a new material, so paint simply lays differently on it compared to the C6 composite material.
If you were to block sand that door prime and more block sand until perfect followed by a coat of sealer then the paint would be straight as an arrow. I'm not saying this is what GM should do. Its what you do when you have wavy panels. if that door was straight with the same material, the final paint would be perfect. Any real auto-body guys out there, I just know enough to see something is a little off.
I dont want to turn this into a paint issue, its not.
Moderator
If you look at the PERFECT angle, you can see them on the doors and fenders. Some are sooooo tiny but they are there.
Drive to me and I'll point them out to you.
2015 C7 of the Year
This has nothing to do with paint. Its the surface that is uneven.
No, my C7 doesn't have ripples down the side. Not all C7s have ripples.
Are you in the market for a C7?
If so, the suggestion would be to find one without ripples.
Good to know that this isn't on all C7's. I'm within reasonable driving range of some major forum deals, might have to take the ride and look at more samples.
Are you saying this varies from car to car?
I understand what you are saying and I wasn't trying to turn this into a paint issue. The bottom line is the material, in my opinion. And, for the record, my statement is accurate. The C7 composite material is different than the C6 material and paint does lay differently on it.
Hopefully some painters comment and give their take.
Moderator
So, I just went out and took a close look. Started beside the car and slowly walked all the way around, looking for any ripples in the doors or fenders. No matter what angle, sunlit side or shade side, there are no ripples to be seen. I even looked at the reflected parking lot stripes. They run perfectly straight. Ripples would cause the stripe reflections to appear wavy. If they are sooooo tiny that this effort does not make them show up then I'm completely satisfied. Its a daily driver, not a show car.
You can come here to see one with no ripples, but I'm not driving to Virginia.
Guess you are lucky then... It sucks that C7 buyers have to be cautious and selective when buying their new car.
It has been uncovered that some C7 paint looks better than others.
No one should settle for ripples on the doors.
