C7 Wheel weights, weight per wheel
Old 10-30-2014, 03:55 PM
Zajac
Zajac's Avatar
Default C7 Wheel weights, weight per wheel
As the title says, I am interested in the actual weight of the C7 wheels, not balancing weights.
Weight of base 18/19 wheels
Weight of Z51 19/20 wheels.
I like that TSW lists the weight of their wheels and I have seen many base and Z51 bare wheels for sale so weighing the wheels should not be a problem....I hope.
Thank you.
Old 10-30-2014, 06:36 PM
RicK T
RicK T's Avatar
You can pull some of that info out of these discussions:
https://www.corvetteforum.com/forums...e-weights.html
https://www.corvetteforum.com/forums...eel-tires.html
Old 11-05-2014, 12:35 AM
EcoBrick Bob
Support Corvetteforum!
EcoBrick Bob's Avatar
I am a bit surprised at the weight of the Z51 wheel/tires of 51.5 lbs front and 60 lbs rear. Part of this is due to the 4 - 5 lb extra weight of the run-flat Super Sports vs. the same size non-run flats. However, there are many after market wheels that will save you considerable un-sprung weight, especially if you switch to the same size Pilot Super Sport non- run flats.
For comparison, my Ford Flex Ecoboost 255-45-20" wheels and Goodyear A/S tires weigh 62 lbs. By switching to 18" Pilot Super Sports on TSW Interlagos, I actually saved 18 lbs a wheel! Tires are 8% shorter, but the weight difference kept the fuel mileage at equal or better.
While my order includes black Z51 wheels, I think I should have saved that extra cost and purchased new light weight wheels, and perhaps also sold my run flats.
s
Old 08-05-2017, 03:35 PM
Pastrulo
Pastrulo's Avatar
The numbers are in, could't find the base wheel weights anywhere, went ahead and order me a set of Z06 replica wheels 18/19 , walked over to the supermarket weight scale and here it is:
2014 base Corvette Stingray Wheel weights:
Front:24.5 lbs.
Rear: 26.5 lbs.
and in case anyone is interested....
The Z06 Ebay Replica wheels:
Front: 24 lbs.
Rear: 29 lbs.
Yes 29lbs!, I was expecting something similar...
ptran00 (05-24-2019)
To C7 Wheel weights, weight per wheel
Quick Reply: C7 Wheel weights, weight per wheel
