Z51 package and magnetic ride control?
on my c6 if you purchased the f-55 mag ride control it included the z-51 package, why are they 2 different options now? if i order the mag ride control what is in this package?
Moderator
You can't order mag ride unless you order Z51. FE4 (MSRC) includes Performance Traction Management.
Moderator
Performance Traction Management (Z51 with Magnetic Selective Ride Control)
Performance Traction Management integrates the Traction Control, StabiliTrak, and Selective Ride Control systems to provide improved and consistent performance when cornering. The amount of available engine power is based on the mode selected, track conditions, driver skill, and the radius of each corner. This light is on when the vehicle is in the Performance Traction Management Mode.
In order to select this optional handling mode, the vehicle mode must be Track. Then quickly press the TCS/StabiliTrak g button on the center console two times.
PERF TRAC 1 - WET ACTIVE HANDLING ON displays in the DIC.
To experience the performance benefit of this system, after entering a curve and at the point where you would normally start to increase acceleration, fully press the accelerator pedal. The Performance Traction Management system will modify the level of engine power for a smooth and consistent corner exit.
To select a mode while in Performance Traction Management, turn the Selective Ride Control/Performance Traction Management MODE SELECT **** on the center console. The Performance Traction Management system contains five modes. These modes are selected by turning the Selective Ride Control/Performance Traction Management MODE SELECT **** on the center console. Scroll up or down through modes 1–5 by turning the MODE SELECT **** to the right or left. The following is a DIC display description and the recommended usage of each mode:
PERF TRAC 1 – WET ACTIVE HANDLING ON
. Intended for all driver skill levels.
. Wet or damp conditions only — not intended for use in heavy rain or standing water.
. StabiliTrak is on and engine power is reduced based on conditions.
PERF TRAC 2 – DRY ACTIVE HANDLING ON
. For use by less experienced drivers or while learning a new track.
. Dry conditions only.
. StabiliTrak is on and engine power is slightly reduced.
PERF TRAC 3 – SPORT ACTIVE HANDLING ON
. For use by drivers who are familiar with the track.
. Requires more driving skill than mode 2.
. StabiliTrak is on and more engine power is available than in mode 2.
PERF TRAC 4 – SPORT ACTIVE HANDLING OFF
. Requires more driving skill than modes 2 or 3.
. StabiliTrak is off and available engine power is the same as mode 3.
PERF TRAC 5 – RACE ACTIVE HANDLING OFF
. For use by experienced drivers who are familiar with the track.
. Requires more driving skill than in other modes.
. StabiliTrak is off and engine power is available for maximum cornering speed.
If you get a Z51 the mag ride is an extra available option but it is well worth it for the handling vs comfort based on when you want it. I think GM should have made the dry sump oil system an option with the Z51 instead of standard though since I don't plan to track my car and would rather not use 10 qts of oil for each oil change.
On the C6, the mag ride option did not include the Z51 option. They were two separate options.
There would be no way that every person that ordered the Z51 option without the dry sump would be like you and never push the car into high lateral g's situations.
Given that, are there $1800 worth of benefits that I could use from the Magnetic Ride Control? What percentage of people order the MRC? Thanks.
I just ordered a Z51 A8 and the MSRP is already at $69k. I doubt I'll use the car at the track (if for no other reason, my insurance won't cover it) so the track advantages mentioned by Zymurgy don't seem to apply to me.
My .02
Moderator
I love being able to adjust the suspension for different driving conditions. I normally keep it in Sport mode, but if I'm on poor roads (rough, uneven, pot holes), I'll switch to Tour mode. Tour mode is also good if you're doing some long trips.
Final, correct 2014 production numbers have not been released yet, but about two-thirds (around 64%) of Z51's were ordered with MSRC.
It IS NOT a track only option nor is it a just to get a softer ride on the highway. It's an advanced suspension that allows the user to dial in the mode that best suites their needs. In addition, it's always active and adapts to the road in milliseconds.
This video is 2 versions old and is impressive. The system in the C7 is significantly improved.
I have regrets about springing for the NAV/PDR but absolutely none about getting MSRC. Being able to change the ride with a flick of a switch is a great option in my opinion and as others have stated it does a lot more than just that.
BTE - this opinion based on using the MRC in my '13 427 vs the Z51 in my '06 convertible.
Do you actually own a C7 with MRSC? I do and I would never own this car without it.
It IS NOT a track only option nor is it a just to get a softer ride on the highway. It's an advanced suspension that allows the user to dial in the mode that best suites their needs. In addition, it's always active and adapts to the road in milliseconds. ]
I have a C7 Z51 2LT. I also have an upgraded suspension C6 (shocks/swaybars) but no magnetic ride/Z51.
The MRC is a must-have for daily driving IMO. I like how I can have plushy ride with some body roll or complete stiffness no roll and handles like a go-kart. My C6 handles very good (equivalent to sport mode on MRC C7). My friend took a drive of both cars. He road races an Evo X and he has a significantly upgraded suspension so he's used to something that can take corners...fast. He feels the C6 needed the upgrade I gave it and feels it handles great. The C7 he did one of these.... . He couldn't believe for RWD how planted the car was to the road, especially under load.
IMHO its well worth the $1800. This is the 1st sports car I've had that my wife actually likes the ride.(Touring mode)
I have a 15' z51 2lt. I debated for on whether or not I wanted Mrc, an I can honestly say I am thrilled that I got it. It makes a huge difference for performance but also for daily drive. I manly drive in sport mode but it is awesome to be able to switch modes depending on my mood for driving an terrain. Money well spent!
