Skip Shift Eliminator
Old 11-07-2014, 03:56 PM
SSBRITTSTL
SSBRITTSTL's Avatar
Default Skip Shift Eliminator
Can you put the same "Skip Shift Eliminator" made for a C6 on a 2014 C7 (Z51-7speed manual) ?
Old 11-07-2014, 04:24 PM
RicK T
RicK T's Avatar
Apparently the C7 is just different enough that the C6 unit doesn't quite work.
See post 65 here (and read the rest if you want):
https://www.corvetteforum.com/forums...post1586451268
Old 11-08-2014, 12:09 PM
SSBRITTSTL
SSBRITTSTL's Avatar
Default Skip shift eliminator
Originally Posted by rick t
apparently the c7 is just different enough that the c6 unit doesn't quite work.
thank you !
Old 11-08-2014, 12:27 PM
Rand1993
Rand1993's Avatar
Originally Posted by SSBRITTSTL
thank you !
As you can see you on the other post referenced above, there is a small projection inside the piece that can be cut off so that the C6 part will work on a C7. I did so on mine using an X-Acto knife and it worked fine.
Old 11-09-2014, 01:27 PM
SSBRITTSTL
SSBRITTSTL's Avatar
Default Skip Shift Eliminaor
Bought a new one made for C7. Thank you!
Old 11-09-2014, 02:05 PM
C7HOORAY
Support Corvetteforum!
C7HOORAY's Avatar
You bought a 70K car and are trying to save 7 dollars????
To Skip Shift Eliminator
Quick Reply: Skip Shift Eliminator
