Hood stinger: GM vs Aftermarket
How does the factory (is it factory installed?) hood stinger stripe compare to having it done locally?
I have seen a few threads mention this. They claim the aftermarket stripe will cost less and look the same. Others say the slight savings is not worth the hassle.
My goal is to have the CF hood stinger with an additional small stripe around it. So if I'm having some hood striping done aftermarket, might as well have it all done then, right? But ...
I talked to a local vinyl graphics place who told me that any vinyl they install on horizontal surfaces will get sun baked and need to be replaced in about 3 years. Is this typical? Is the factory stripe good for many, many years?
SUPPORT AUTISM
Moderator
Unlike the aftermarket stripes, the factory stripe is actual automotive paint (color and clear coat) applied to a vinyl substrate.
Thank you, jacquesc6. I did see the paint vs stripe discussions, but I was not planning to paint. I'll do additional searches to see if I can find out more about the vinyl options.
Also, thank you Eppieguy and Zmurgy!
SUPPORT AUTISM
If Vinyl is what you want, there are several Forum vendors that sell stinger stripes. Ask them how the quality is compared to the factory stripe. I mentioned painting because it cost me half the price the dealer charges for vinyl.
Some of my old cars had vinyl tape and if you were not careful and got some wax on it, it was near impossible to take off. Left a light fog type mark. Is this true for the newer vinyl ?
New high quality vinyl will not do that with just wax, compounds may be a different story.
yet you can't tell at all from a good vinyl like Oracal 951 black metallic....Oracal has about a 7 year life, the GM stuff is about 9 year, acc to Talon - a gm source. If that 2 years is worth 3 times what a vendor here will sell you an Oracal stripe for, then do it.....
But don't get sucked into the GM Kool aid that you are getting a stripe that LOOKS like clearcoat...because it does not...and I have had mine side by side with a gm stripe...IDENTICAL....
10 4 -if you don't want to mount or mess with it, GM is the way to go....but people should not think they are getting the equiv of a good painted clear coat job, because it's not that...
