How to get out of park
The new C7 is now parked for the winter, on keyed cars just putting the ignition in the run position you can move the trans into neutral. On the vette A8 auto, how can the trans be put into neutral without starting the engine. I like to move the car a little to avoid flat spots.
Tnx
Tnx
-Mark
Did you try it? I don't know for sure if it will work. I don't have an automatic to verify.
Yes, thanks much. When it is cloudy out, I like to roll the car out, wash it and then drive it back in. Didn’t know how to get the car out of park w/o starting it. Don
There is a diagnostic mode that you can put the car in. I use it to move them around and to demonstrate all of the features without having to actually start the car. This is what they are talking about above.
Hold the start button for 5 seconds, the car will ding and all of the systems will light up. At that point everything works in the car as though it is running, without actually starting.
Mine takes closer to ten seconds, so don't give up!
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
I always heard don't move an automatic in neutral.I know towing an automatic I believe Ya have to disconnect the driveshaft.This is on A non Vette.I wouldn't tow A vette.
I guess moving in A few feet don't hurt it.
Check your manual. Most automatics have a over ride button close to the shifter that allows you to shift to neutral (a small plunger, etc. to press with a screw driver). This is used if the engine/battery is dead and you need to move the car.
