Wheel center cap removal question
I did a search but could not find anything on this.
Has anyone tried to remove their Z51 wheel center caps without removing the wheel. I purchased a new set of center caps and thought I'd change them out while the car is put away for the winter. I'm concerned about damaging the wheel and the center caps I'm removing if I try to pry them out. If you have any experience with this any assistance would be greatly appreciated. Thanks for your time.
Mj
Mj
[QUOTE=mjross;1588322253]I did a search but could not find anything on this.
I was able to remove the caps from base wheels, should be similar. Use an optical size very smooth polished screwdriver to back the cap away from one edge and raise slightly, then use a second very small screwdriver to reach in under the very lowest part of the edge of the cap, should lift right out with no damage, did on mine but proceed slowly. My wheels are chrome if yours are paint you might put a layer of masking tape where screwdriver lightly prise against paint.
Moderator
You can pry them out without removing the wheel, but you must use a non-marring tool like plastic trim tools. Anything else risks damage.
Thanks gentlemen! I appreciate your time. Have a great weekend.
Mj
Mj
this method works like a charm. Use same piece of velcro tape for all four wheels. Takes 2 minutes....no damage.
wheel center cap removal the easy way! - youtube
Indy 28,
Very creative approach...................
Now that is just plain clever! Thanks for posting...first time I've felt the need to say that.
this method works like a charm. Use same piece of Velcro tape for all four wheels. Takes 2 minutes....no damage.
Wheel center cap removal the easy way! - YouTube
Moderator
I'm not sure I'd try that Velcro tape trick on the Stingray center caps. The Cross Flags and circle is a separate part and there is a very real chance that when you try to remove the tape you will pull off the Cross Flags.
Indy 28 -- Nice! Thanks for posting this very helpful tip.
I hear ya, but I've done it 8 times....no problem.
joeybsyc (12-06-2016)
Moderator
Maybe I bought the wrong Velcro but it is made by Velcro and says 2000 lb test. almost impossible to separate the sticky barrier tape but I got it done. Pressed it on the center cap real well as shown, grabbed with pliers and gave a big yank, NOTHING BUT TAPE came off.
I'll try again but I don't think it will work. I have stock GS Chrome wheels BTW
NSF
NSF
NSF
NSF
Not So Fast (05-22-2017)
