New Z51 C7 overfilled oil?
#42
In september I purchased a 2015 Z51 in Michigan and drove it home to the Pacific Northwest. I first checked after a few hundred miles and it was an inch above the full hash mark or where the OP indicates his was.
When I got home I had the oil changed but before I took it in I pulled the bridge between the air filter and the manifold and it was full of oil.
The dealer cleaned that area and the PCV lines. I told them to put in 9.0 quarts and they obliged. This put me just under halfway between the dipstick marks . After 1500 miles on the new oil change, I added 4 oz to keep it at the halfway mark.
#43
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
#44
To put it another way. I measure the oil level on a hot engine according to GM protocol, then add or remove enough oil to put the oil level in the center, or just below center, of the dipstick hash marks. The next morning when the engine is cold, I check to see where the level is on the dipstick. Wouldn't filling to that level on a cold engine, give me the correct oil level, which would read to about midway through the hash marks when engine is hot?
#45
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
I follow that logic and I would concur. Let the car sit for 3 or 4 days and note the location of the oil on the dip stick. If, when hot, the oil settles in at mid-hash I would conclude that you can fill cold if you use the ascertained "cold" dip stick level. My question is, "Do you get a reading on the dip stick after the car sits unused for 3 or 4 days (or longer)?"
If yes, then we have a cold level oil mark that we can refer to. If no, then you must check and adjust with the oil hot.
Elmer
#46
Elmer
Elmer
#47
#48
#49
That would work if you had any indication of oil at all on the diptstick. Try it for yourself, but I think you'll find that oil will gradually drain out of the tank overnite so that there is no oil level visible anywhere on the dipstick the next morning. At least that's been my experience on two dry sump Corvettes.
Elmer
#50
This summarizes the issue perfectly. Measure the oil hot, just the way the manual describes. And do it at 5 or 6 minutes after shutting the engine down -- even at 10 to 20 minutes, you'll start to see a drop in the oil level.
#52
