Is the NAV problem fixed at the factory?
Received 9,517 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
one of these days the car manufactures will wake up and forget about a lot of the stupid electronic gizmos and get back to building a car with gauges and just a very few other things or spend the money on quality equipment...I'm seriously looking at the Alfa Romeo 4C which comes without power steering and whose options are air conditioning and a radio with a signal speaker and a few other things...before you all jump all over me about this car, have a look at the car mags. that road test it..it is a driver's car in the real sense of the meaning...it's been called the baby Ferrari and to coin a phrase...goes like stink.
I was thinking that the NAV problem was the long poll in the tent, and these other issues would be fixed even sooner. I guess I'll just add them to my list of things to check when I take delivery.
And the 500 mile oil change is a given, but I'm hoping to avoid an extra trip to the dealer. In the mean time, my C6 runs perfectly with zero problems.
Now that you know you can get a C7 with a working Nav, and won't have to return for the fix, please let us know when you'll be picking it up.
Oops! I forgot to mention. GM has a Navigation Map Upgrade for the C7 now. Optional of course, but if you want the latest maps and POI's it will probably mean another trip to the dealer.
Care to elaborate on the areas I bolded? I'm not familiar with these potential issues. Either describe or URL please.
The issue involving low fluid in differential has been reported randomly by members of the various forums. If I remember correctly certain individuals reported a noisy differential. I had the fluid level on mine checked just to make sure. It was fine.
The issue involving over filling of the engine oil from the factory has also been mentioned randomly on various forums. GM recently released an notification about slightly reducing the oil level. I'm not 100% sure but this may only involve Z51's. Search for additional info.
Certain C7 VIN's fall subject to the Emergency Brake Recall. Check here for your VIN: https://recalls.gm.com/#/ My 2015 C7 (purchased in late August) had to have this recall done. It involves something to do with the emergency brake cable(s) not be properly installed from the factory. It was a quick fix.
I have this issue and the local dealer is NOT fixing it, nor is GM being helpful. You would think if they are now fixing this at the factory they would admit earlier builds had a problem.
I admit I'm curious to see if using the PDR clears the problem, even temporarily.
GPS/PDR problem
Thanks Heidemarie
My PDR says: No SD card inserted although the FAT32 SD card is in place in the glove box SD card reader; therefore can't activate PDR and GPS has red X over GPS symbol.. My dealer has ordered the 3M aluminum foil tape and whatever other parts are needed to fix the problem (supplier is a subcontractor Not GM) and parts have been on order now for over 3 weeks and have not come in yet. If you can activate your PDR let me know please; surely would like to use my PDR in the meantime
Thanks Heidemarie
Thanks Heidemarie
Thanks Heidemarie
Thanks Heidemarie
Also if your Navigation fix hasn't been done yet, odds are your PDR won't be able to provide accurate GPS track data.
#34
What size memory card did you insert in your glove box? I seem to remember hearing somewhere that there's a size limitation to the PDR memory card. That limit might be 16gb, but don't hold me to that. Anyone know for sure?
#35
I'm using a 32GB card in mine so 16 is not the limit. IIRC it's somewhere around 900 minutes of recording time.
#36
Thanks Heidemarie
Thanks Heidemarie
#38
my PDR still does not work. I have reseated the Fat 32GB SD card SEVERAL times hoping it would finally connect; but to NO avail; Of course the SD card is plugged in the slot in the glove box. Since I can't even activate my PDR, I therefore cannot get the X off the GPS either. Strange that both the GPS and the PDR were working fine for the first 4 weeks and then I had the car battery crash on us and we had to be towed to a Chevy dealer here in Ft. Pierce (not our dealership where we bought the car)to get a new battery. After we got the car back we noticed the msg. NO SD CARD INSERTED although the card was there in place. Took it back to the dealership in Ft. Pierce (since they worked on the car)and they could not fix it but GM said "they are aware of the problem and working on it" Then Called our service Dept. in Melbourne and they have ordered the neccessary parts to fix the problem per GM instructions; Still have not gotten the parts in (on order from supplier since 23 Nov.)
Glad yours is working!!!!!! Heidemarie
