If you put different tires on a Z51 car wil it stop WHEEL shutter and hop?
Received 3,096 Likes
Finalist 2020 C7 of the Year -- Unmodified
Looking at a 2014 Z51 vette with Michelin pilot tires have noticed when dirvng at low speeds backing up and turning that the car shutters and has wheel hop. If I was to put different bigger profile tires on the Z51 rims will it stop all the NONSENSE . I drove a non Z51 2014 vette with the base suspension and larger Michelin pilot tires with more beef on the sidewalls which are also softer and thicker tires and did not have any problems when I put the car in reverse or slow turning motions . The non Z51 car was as quiet as my current 2008 C6 with F55 suspension. Thanks Dave.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,817 Likes
2015 C7 of the Year Finalist
Ackerman effect. It's the way the suspension is built. You can put hula-hoops on the rims and you will hop when the speed and turning radius are correct.
Search Ackerman and you'll get tons of threads discussing it. It's also mentioned in the owner's manual and called "normal" in the book.
Elmer
Elmer
After mounting Michelin A/S 3's for cold weather use on my Z51, I am no longer able to reproduce the wheel hop experienced with original summer tires. Same size tires were mounted on std Z51 wheels. Not suggesting the this is a cure in all driving situations, but it was a nice side effect for my normal driving and parking. As temp dropped, the summer tires seemed more prone to hop, so the different compounds must have caused a change. Since my C6 had the same issue, I don't consider it to be a problem, just a routine response to tight turns. No big deal.
It's either hopping or sliding smoothly. The tire is wearing, you might not feel it as much as the OEM Michelins.
Elmer
Elmer
Anyone know whether other sports cars have this hopping? When I'm pulling out of parking spots or making tight turns, it's embarrassing. I'm just curious if that happens during autocrossing events?
I do wish GM had given the customers a choice the tires we got with our C7's.
I am a C7 Z51 owner and have heard the 'noise' of the tires when the temp drops below 40 degrees. Well, I broke down and bought the Michelin A/S tires - an expense I was not happy about (I had 9,900 miles on the original tires). But . . . now that I have them mounted I am pretty happy with them. Besides no below 40 degree noises, I can now hear the stereo much better, they seem to ride smoother and I am not positive but it seems as though I might be getting about 1.5 mpg more - was not expecting that and the colder temps may contribute to that - not sure.
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Wife's Shelby does it at full turn. Other cars do as well. If you don't like it just don't turn the wheel all the way and it won't happen. I've never understood all the worry about it, and will NEVER understand buying new tires to try to prevent it.
Even my CTS-V would do it when cold. Not sure why it's embarrassing. More telling that the tires and suspension is setup for performance and not getting groceries.
Received 1,981 Likes
Me too.... works as described above.
I like getting groceries in my C7 and all the vettes I've had since early 70's. I still say that MOST vette owners do not race, but just want a great looking car along with a little performance. Never had any issues with my two C5's which my wife did not want to sell, but now I have to hear remarks here and there about this car's tires hopping around, headlights and flex plate being replaced,DIC going dark and not enough room for groceries(just kidding about that). But I do love the car and have not had any time to really drive it due to breakin period and now the cold weather. Just hope my tires don't crack, since it sits outside all year. And to get out of my driveway, I have to turn the wheel tight to keep from scraping the splitter, which I have already damaged.
E-Ray, 3LZ, ZER, LIFT
Received 9,615 Likes
This is a PDF with 4 pages of pics showing the issues that cause what GM calls “Chatter.” http://netwelding.com/Wheel_Chatter.pdf
Issue is much worse in my Z51 C7 than my Z51 C6 with same section width, but Goodyear and Firestone tires. A number of posters say it goes away with all-season tires. However all you have to do is not turn as sharp when the tires are cold! Make a “K” turn like I do until they warm up, which they do quickly. Perhaps you have other reasons for all-season tires, looking at where you live. But certainly don't spend the money and sacrifice performance just to avoid "chatter!"
Same exact experience after changing to the AS 3s @ 9k miles.
Owners manual clearly ststes its normal and does not need service.
