Joining the Blown Engine Club
St. Jude Donor '15
Best of luck on your issue.
I Lemon Lawed a Vette in 1998, what a pita! Did get a new car, though. But it took a lot of effort and the dealer really helped me out. Way better than a new engine.
But a new engine is way better than a rebuild.
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
You're jumping the gun a little. This isn't a lemon law situation. And manufacturers don't just give you new cars because yours needs a repair. This is why GM gives warranties.
You are absolutely right! I will follow the process and it leads to where it is intended to go.
After they put it on the lift yesterday and listen to the noise from the bottom they think it is the motor. I will see what they say after Monday check out.
The car has been really great till this point so I can not complain. We all hate it when things happen to our Baby's and they have to go to the shop!
Press them on that point until they give up the truth. Threaten GM that you are going public and to the media if you do not receive satisfaction. Find one of those Channel on you side reporters. Tell them your story and then show them the valet story.
They service manager said that he was the QC guy and he was checking the car to find the problem. When he got back to the dealer he stopped the car and it would not start again.
The funny thing that I remember today is the Service Manager said the car quit running a couple of time when I was talking to him. I am not sure what is going on with the 109 miles just seemed like a lot of miles to me for any checking of the car!
So if they drove the car 109 miles but after they put the new starter in it they did not drive it really at all. Seems they should have drove it a couple of miles just to check that solved the problem. So if the rod bearing was going bad and it took more force to turn the engine it could have caused the starter to go bad?
So when it stopped running Tuesday I could not get the car to start at all for over three hours. I was not till the tow truck got it back to the dealer it started while we were getting it of the truck. He just push the start button and it started but was running really ruff and would not run long at low rpms.
Well I guess I have a few things to figure out on what and why!
Good luck.....my guess is you'll be without your car for at least 3 weeks.
You should get rid of this car. Even if GM agrees to a new engine, it will still be a warranty repair, meaning that GM will probably not allow the dealership to charge full shop rates to perform this complex job. Time is money --the dealership and the tech(s) may hurry the process to beat the clock. I don't think you want this. You paid big bucks for Chevy's halo car -- the engine should last much longer than it has. C7s are plentiful now, try to work out cash back/credit deal.
#33
#39
So this October at 6900 miles, my Z51 engine went into limp mode and was making a lot of valve train noise. Being a mechanical engineer, I didn't abuse the car and always made sure that it was warmed up well before any kind of hard acceleration. They replaced all the lifters, but the noise was still there. GM said that they should take the motor fully apart to determine what was really going on. I insisted that they just replace the engine with a new unit. The dealer really went to bat for me and got approval to get a new crate engine.
It only took two days to get the engine once the factory engineers approved its replacement. By the way it wasn't a rebuilt unit but right off the 2015 production line. This early in the game they didn't have enough engines to rebuild which I was real happy about. When I got the car back, I couldn't see anything that looked out of place and you would never know that a new engine was installed, so the technician did a great job. The only issue I've had was a warning that the e differential needed servicing. Apparently one of the electrical plugs wasn't seated properly.
So after 2,500 miles, no problems with the new engine. I've also noticed that the clutch is smoother, possibly due to less crankshaft endplay, who knows? Anyway, I was always nice to the service manager and he was very good about keeping me informed. In a year or two, I will use this experience to negotiate a good deal on a new Z06.
#40
