Tell us how you really feel about throttle response?
#61
I just installed a Vitesse Throttle Controller last night. It can be done in about 5 minutes, or longer depending on how integrated someone wants it to be. The difference is night and day. It doesn't make the car "faster", but it definitely wakes it up during normal everyday driving. The difference is noticeable at setting 5, and setting 9 makes the throttle response hyper-sensitive. For now, until I get more used to it, setting 7 is great.
I think it makes driving the car much more enjoyable around town.
#62
Trifecta
I have a 2015 C7 base model A8 with NPP. The only mechanical mod is a drop-in Air-Raid (dry) filter.
I went the full tune route with Trifecta -- disabled AFM, increased throttle response, added 30 ft-lbs of torque, and the A8 shifts better.
Enjoy the car a lot more. Cost $300, that was back in May 2015.
#64
I don't think I've seen anyone else say this. My experience, and that of many people who've posted, is just the opposite. 50% travel is far less than 50% throttle. I don't mind it so much, though, as it makes the car much easier to drive smoothly in typical public road conditions. I also have a C7 manual and typically drive in sport or track mode. Mine is a 2015. What year is yours?
They're not going to unleash a car with 450 HP on the general public with highly sensitive throttle response.
Remembering the days of direct throttle linkage comes up a lot.
But what you don't hear is, back then that 450HP car did not idle at 550 RPM like today's C7.
It idled at 8-900 RPM so it wouldn't stall, and around town you were either idling along in traffic or going like a raped ape at the touch of the gas pedal, there was no in between
Don't like your C7 throttle response ?, get one of those aftermarket throttle booster products
#65
No. The throttle response in all modes is significantly improved with the Vitesse Throttle Controller - including Sport and Track. I usually drive in Sport or Track, and the difference before and after installation is substantial. It really makes the car more responsive and enjoyable to drive. It's also easy to remove without a trace, unlike most (maybe all) tuning options.
#66
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
I drive in Sport 95% of the time and feel it's fine. If I want a faster response I push faster. GM has used a non linear curve for the C7, probably even in sport 50% peddle is not 50% throttle body. You can get a simple add on device that plugs between the peddle and throttle body electrical connector to make it linear. Note I said simple not cheap!
I'm reminded of my 1st car a '41 Ford Opera Coupe that I replaced the flathead with a bored out Olds engine. That OHV engine was significantly higher. I had to have a 6 inch extension brazed to the throttle linkage. There was less than 2 inches of travel on the accelerator peddle! Sounds like some wish they had that response. Cheap way to make folks think they have more hp then they do.
#67
Originally posted by JerryU: ...You can get a simple add on device that plugs between the peddle and throttle body electrical connector to make it linear. Note I said simple not cheap! ...
What device are you referring to?
#71
#72
Actually I was, one I had copied the graph they published. It's call Sprint but cost even more! This shows the OEM is linear, not sure it is on the Vette. Their devise, as noted, reaches 100 % throttle body opening at 1/2 throttle!
My 16 year old graddaughter inherited her sisters Jeep Hemi. That throttle is so sensitive it's dangerous IMO. I drove it and it was a bit scarry! Daughter said she is used to it now and the dealer wants $200 to fix it. It's 8 years old so proably can't get Jeep to do anything at this point.
Device just plugs into connecto on acclerator peddle.
#73
Not for me.
Talk about over working something to get the same conclusion, this is it.
Had a Sport button on the BMW's I've driven, just increased the response to the gas peddle, and made the car a uppity bitch. Rarely used it.
I prefer what the car came with. Sure it take a little more time, but not that much, and in the end I get the same conclusion. I don't mind taking my time, it just smother
ride that way. I don't mind, and even like, what GM engineered here.
Chemdawg99 (06-26-2016)
#74
Actually I was, one I had copied the grapgh they published. It's call Sprint but cost even more! This shows the OEM is linear, not sure it is on the Vette. Their devise, as noted, reaches 100 % throttle body opening at 1/2 throttle!
Device just plugs into connector on accelerator pedal.
Thanks for the clarification. The Sprint Booster device is almost twice the price of the Vitesse. It apparently has two settings -- three, actually: Inactive, "green light" for "smooth driving" and "red light" for aggressive driving. Red light must be the mode shown by the blue line in the graph you posted. I like that the install is easier, they have a 30-day money-back satisfaction guarantee and install is simpler because you don't have to hide anything or run any wires. But the price is a bit much.
Expecting to get my car towards the end of the week. (It's on a train heading this way since Friday.) I'll drive it a bit then see if I have to have a gas-pedal helper.
#75
#76
So I am trying to get more feedback on how C7 drivers feel about the throttle response.
What I want is a car that responds like my old fox body 5.0 mustangs did. I can still distinctly remember the first time I ever sunk my foot into the pedal and felt the pull of 300 ft lbs at about 3000 rpm in a 3000 lb car. It was exhilarating. I then moved on to a modded 89 that probably made about 400 ft/lbs and had 3:73 gears. That thing was so much fun.
I am looking to return to those days in a more refined package with decent handling, and the C7 seems to offer much promise in that regard. But when I test drove a 2014 Z51 m7 back in November 2013, it did not respond like my old 5.0 mustangs did, even in track mode. It was more like an on/off switch, if I really layed into the throttle it hauled like a train, but at lower throttle inputs it did not pull all that strongly. Perhaps this a function of GM torque management throttle mapping?
Some C7 drivers seem to feel the same thing, noting that it seems that 85% throttle is needed to really get that push in the back. Others say that the throttle response is amazing and have no complaints.
The discrepancy is hard to understand? Are those satisfied with throttle response perhaps the types who always lay hard into the throttle whereas those who find the throttle response less than ideal are the types who maybe hit the throttle a little more gingerly?
How do you feel about your C7's throttle response?
The Jag was just plain scary fast; the Corvette is more sedate.
#77
Echo all sentiments in this thread - C7 fly by wire throttle programming is very mediocre from factory. All modern fly by wire cars have dull throttles from factory (they do it for emissions?) but the C7 is particularly bad.
I put a Vitesse in, and that improves things significantly, but throttle is still a problem. Car feels a lot slower than it should, for its numbers. One of those things owners just need to learn to live with.
#78
HORRIBLE!
I have an M7 and had to use revmatch to downshift. Since I have purchased the Vetisse Throttle Controller and set it to 9, I have never used Revmatch again. It has made my car fun to drive. You can blip the throttle with ease. Love it and my M7.
Pete43 (10-02-2018)
#79
amazing
The more I read about the C7 the more I realize how much has been given away in the process of making more hp from less gas. I had no idea that the throttle response was subject to such complicated programming. I guess the key is that it is throttle by wire...and in such a system the manufacturer can play any games they want.
After reading this thread I realize that it is not possible to directly compare the old cars "lower" factory hp with the new cars "higher" factory hp. The programming of throttle response sits in between the driver and engine response. I'm still reading and learning but so far I don't like the message.
#80
I'm shopping for my first vette. My background has been decades of restoring and driving mid to late 60s muscle cars. These cars are very primitive of course but the throttle response is immediate-the linkage is mechanical etc.
The factory "throttle by wire" settings help make the power available more "usable" for many of today's drivers who would likely wrap a late 1960's big block C3 around a tree in short order.
