Tell us how you really feel about throttle response?
So I am trying to get more feedback on how C7 drivers feel about the throttle response.
What I want is a car that responds like my old fox body 5.0 mustangs did. I can still distinctly remember the first time I ever sunk my foot into the pedal and felt the pull of 300 ft lbs at about 3000 rpm in a 3000 lb car. It was exhilarating. I then moved on to a modded 89 that probably made about 400 ft/lbs and had 3:73 gears. That thing was so much fun.
I am looking to return to those days in a more refined package with decent handling, and the C7 seems to offer much promise in that regard. But when I test drove a 2014 Z51 m7 back in November 2013, it did not respond like my old 5.0 mustangs did, even in track mode. It was more like an on/off switch, if I really layed into the throttle it hauled like a train, but at lower throttle inputs it did not pull all that strongly. Perhaps this a function of GM torque management throttle mapping?
Some C7 drivers seem to feel the same thing, noting that it seems that 85% throttle is needed to really get that push in the back. Others say that the throttle response is amazing and have no complaints.
The discrepancy is hard to understand? Are those satisfied with throttle response perhaps the types who always lay hard into the throttle whereas those who find the throttle response less than ideal are the types who maybe hit the throttle a little more gingerly?
How do you feel about your C7's throttle response?
BarneyZ (11-23-2016)
Volocty (05-31-2016)
Received 2,379 Likes
it's all in the tune, like always.
twisting the distributor, changing the jets, adjusting the throttle cable, etc etc is all done on the laptop now.
I used to remember the fox body as being an amazing awesome machine, but let's be honest.....it's a huge lump of crap compared to the cars we have today. get in one today and drive it around the block. its a 4 lug turd.
Even with the 5.0 (I had two of them) there were things we needed to do in order to get better throttle response from them. Right out of the box they were ok, but everyone with a 5.0 would immediately pull out their timing light (remember those??) and bump the timing to 13 or 14 degrees. That alone was a huge difference in throttle response. Another good trick was playing with the throttle position sensor, I remember one of mine was set very low from the factory and playing with that gave a nice boost in throttle response. And the best thing of all was swapping out the stock 2.73 or 3.08 rear end gears for a set of 3.55s or 3.73s. I went with 3.55s and the throttle response was instantaneous with that change. Combined with the 3000 lb curb weight and those cars definitely moved, from the instant you hit the gas and even at low rpms.
So fast forward to now, and the C7 can be improved upon in a similar fashion, you just need the right person to tune it. Nothing is ever perfect out of the factory, the 5.0 certainly wasn't. But it's not super expensive to rectify either.
Z06NJ (10-13-2016)
What implications do such tuning alterations have on warranty?
Indeed the fox body's are crude in many ways compared to modern cars, but they definitely had nice throttle response at low rpms...
I just want that with the other refinements we've gained!
Keep it in the good rpm range and tr is decent, I'm not all that impressed with it and I have a Diablo tune.
I also have 2 5.0 ('91 LX and '88 GT) and while not as refined as today's cars they are a blast to drive, many people don't like them because those people can't drive a car that doesn't have all the nannies attached to it (abs, tc, sophisticated suspensions), those people I like to call metrosexuals.
I find that for a drive-by-wire car, the throttle responsive in sport and track mode. The first two gears seem very responsive while the higher gears are a little less.
There have been several posts on this forum about the poor throttle response. I just don't believe we will ever see or get what we had in the "old days" with direct, mechanical throttle linkage. We live in an automated world now and going back to those "old days" methods just aren't going to happen. I always drive in the "track" mode to get the supposed best throttle response, but it's still no where near what we use to experience with the direct, mechanical linkage. Some say a special tune will help, but I'm skeptical. Oh well, we might as well get used to it...
I have no problem with the response. I put mine in the proper gear for the response I want. The car actually accelerates quicker than it fills based on watching the speedometer. Awesome car.
off idle throttle response
It's been sometime since I've chimed in on this problem. And it is a problem in spite of what some on this forum tell you. This is especially noticeable on the stick cars. I've done a lot of investigation into the problem and what is going on is a lean off idle throttle response. If you are at a stable idle condition with foot on the brake to prevent roll back (yes I now about hill assist but it isn't always active) upon lifting off the brake and a quick jab of the throttle as you engage the clutch to prevent roll back the engine goes flat due to lean condition. It is almost impossible to prevent roll back without a stall! Eventually it became evident that the throttle management software is based on torque demand and not airflow so in a stick car you don't have an immediate call for torque so the engine goes lean. Say I'm stupid and don't know how to drive but I've been driving high perf cars for 50 years both carb and FI the C7 is the worst off idle car I've ever driven. So what did I do? I'm currently having Lingenfelter Performance fix it for me since the Bow Tie guys won't do anything unless you get a check engine light!
I think the throttle is sluggish in every mode compared to live throttle linkage cars. I compare the C7 with my C4. Sure the C7 is stronger and faster but the response is no where near as "right now" as the old cable operated throttle in the C4. A clear example is sitting at idle and revving to hear the exhaust. That old C4 is lightening quick to respond, not so with the C7. Think about it for a second, the computer has to sense the gas pedal moving via sensor and respond by energizing the throttle motor. Got to be a slight lag compared to cable operated throttle and I can sure feel it.
-Mark
Throttle response on C7 is very "different" than that on my previous car - 2009 Z4 35i with DCT
Took a few hundred miles to adjust to the difference in the C7.
I'm in sport or track mode all the time, learned to use paddle shifters on the fly or shift into manual shift mode at the appropriate time, and how to modulate the gas pedal throughout the HP and Torque range for best response.
Delayed or slow throttle response is a non-issue.
JST4PLA (05-29-2016)
Pedal to the metal as the saying goes and all is good. Just look at the 0-60 and 1/4 ET.
I am very satisfied with throttle response.
Mine felt a bit sluggish in the first month or so. It has improved greatly, the entire drivetrain has gotten steadily more smooth.
At 4800 mi, I find the throttle response excellent and more power is just a modest throttle movement ahead.
Old 5.0 Mustangs? I had one of the later 5.0s and this car would simply slaughter any of them that doesn’t have higher numerical gears and forced induction. If you think otherwise, you’re glorifying the past. Don
St. Jude Donor '15
I find it to be somewhat lacking. I have a M7 and it is loads of fun...but if you are just easing the clutch out it will stall if you don't kick the throttle. Never had the problem with my C6. Don't get me wrong I love the C7, it's quick and will put you back in the seat with the right gear. I notice it more on the highway when I am gently trying to pass on the interstate.
It is just not the old feel that was around 17-18 years ago. I also feel that some of this has to do with the CAFE regulations that are so much of todays car manufacturing. This is OK because we now have very fast cars that get good gas mileage.
But it is lacking in the right now get up and go feeling that you got with the mechanical linkage of years ago. A quick down shift will fix that problem, though. Nothing like 2nd gear for passing.
