Mirror tap for radar detector for '15 Z51
#101
You'll only see power from the purple wire on the car side and only when the car is running. NOT in accs. mode. I used the purple wire for power and mines worked fine, and I know multiple others have as well.
#104
3rd Gear
Thank you so much, I was only trying it in acc mode not starting the car.
#105
#111
Really appreciate info here and in other similar threads to help folks DIY on these. I would not have the confidence to try this without the details and pictures provided.
Took me longer than I would have liked to get the pins in place. Once I stopped trying to get them where I wanted them and found the positions where the pins would more naturally fit, then it all came together. I had to keep telling myself to NOT resort to needlenose pliers lol -- it does work with fingers only.
#112
Received 4,684 Likes
I am unable to get the cover off. I tried using a prying tool, a screwdriver, I just can't get the cover to budge. It's almost like it's glued on! Did anyone else have issues getting it off?
#113
Yes. It's not glued but their wasn't any room for me to use my plastic pry tool initially. I used a small eyeglass screw driver at the top of the cover to pry just enough to slip in my trim tool. Be patient and check all around the cover. I was seated in the passenger seat when I performed the wire tap process. Good luck.
#114
Just finished a 1400 trip up the east coast and used both Waze and my V1. I would suggest using both! Found many places Waze had the cops but they were long gone when I got there.
#116
I did this install the other day for my V1. Had same trouble with pins but then tried different sides and found that both pins slid in with only a little effort when pushed in on a particular side, so if it won't go in try another side. As far as cutting a notch I had enough room just running wire out the top as it is open and so wire is in between top of plastic cover and liner, which is soft.
Thanks to all who took the time to write about their install and posting pictures. It gives us all the confidence to take on these upgrades.
Beekeeper
Beekeeper
#117
Super write-up, thanks for sharing, placed my order for the mirror tap and will follow your process.
Took my car in Friday for oil change and decided to have the dealer do the mirror mount job as well.. They followed the method posted and all is good.
#118
Invisicord
Has anyone used an Invisicord wire tap, will this work on the C7? I used this on my C6 with a Valentine1 detector.
I'm assuming the red wire with a yellow wrap goes to the purple on the car side and the green wire with a black wrap goes to black on the car side?
Thanks for your help.
#119
That is correct. Did mine today. VERY hard to get the cord ends into the wire harness/plug. I filed them down as much as was safe to do, and even then it was next to impossible to get them to make contact. It works now, but I will probably have to solder small pins on the ends of the Invisicord wire in order to make good connections. Generally a PITA to do, compared to other cars.
#120
2015 Z06 Convertible
-- the 2015 Stingray Convertible/and Z06 Coupe/Z06 Convertible -- do these 3 cars in fact share the same mirror ?
