Mobil 1 Use ONLY
#581
The Service Mgr reviewed the camera and they did install 6 qts 5-30 Mobil. An offer to redo the service was extended. Not necessary, my biggest concern was having 30 weight in it for a 2000+ mile trip in a week.
The dealer did what I asked. Sloppy documentation is what tripped up the visit. I'm sure they will pay better attention going forward.
#582
Received 1,738 Likes
St. Jude Donor '15-'16,'18
I thought I read in the owners manual that an oil and filter change required 7 quarts for the dry sump motor?
#584
It fit with zero modification, the cap is identical to the stock C7 dry-sump cap with the exception of the Mobil1 logo instead of DEXOS.
I picked it up for $18.41 shipped from Rockauto (after 5% discount code); this is the cheapest I could find it without having Amazon Prime. I ordered it late Thursday afternoon and it arrived Monday.
#585
#587
Maybe this will help with the Dexos debacle.
I went to my new Chevy dealer for an oil change this morning (I relocated). We went through the whole Dexos vs. Mobil 1 routine on my non Z51 2014 Stingray. I showed them the memo posted here on CF. They still were not convinced. Finally, I said "do what the hell you want to do with charges, but put Mobil in the G.D. car! Five minutes later the service manager came back, and said they investigated, (??????) and found a BRAND NEW GM instruction dated June 9, 2015 that makes all the crap we have been going through crystal clear. The Document ID is 4212517, and it is PIP5290A, and supersedes the original 5290.
on the very bottom under "Tip," it reiterates:
"USE ONLY MOBIL 1 WHEN PERFORMING AN OIL CHANGE ON ANY CORVETTE UNDER THE CHEVROLET COMPLETE CARE PROGRAM.
I hope this will finally bring an end to the problems we have been having, but I doubt it.
#588
Here's the cross-list reference for this particular cap:
CADILLAC CTS (2004 - 2011)
CADILLAC DTS (2008 - 2011)
CADILLAC SRX (2004 - 2009)
CADILLAC STS (2005 - 2010)
CADILLAC XLR (2008 - 2009)
CHEVROLET COBALT (2008 - 2010)
CHEVROLET CORVETTE (2006 - 2013)
CHEVROLET HHR (2008 - 2010)
PONTIAC SOLSTICE (2007 - 2009)
SATURN SKY (2007 - 2010)
#589
Took in in today for and oil change. Service writer stated he only uses Mobil 1. I got the car back and there was oil on the door and center arm rest but they used my pucks and no broken rails. When I got home and looked at the paper work it read dex 5/30. Called dealer back and they said bring it back in and we will make it right and they drained and changed filter. First visit 2 hrs 2nd visit 1hr. F this much better just to do your self and know it is done right.
#590
#591
Absolutely incredulous that we are still hearing stories like this. I agree with you. Buy the oil on sale at Walmart and a filter from the dealer and do it your self. The "free oil changes" are not worth the hassle. Sorry to hear about your story. I wouldn't go back to this dealer. You must have a lot of choices out there on the west coast.
#592
Car only goes to dealer for critical stuff that I can not fix myself. And then I worry while it is in there about what they will break next. Sad.
#593
#594
#PIP5290: Oil Change information For 2014-2015 Chevrolet Corvette - (May 11, 2015)
Subject: Oil Change information For 2014-2015 Chevrolet Corvette
Models: 2014-2015 Chevrolet Corvette
6.2L LT1 with wet sump oiling system or non-Z51
6.2L LT1 and LT4 with Option Z51, Z52, and Z06 Dry Sump Engine W/Manual or Auto Trans
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Oil Change Information on 2014-2015 Chevrolet Corvette as stated in the Chevrolet Complete Care Program
Recommendation/Instructions
The 2014-2015 Chevrolet Complete Care Program for Corvettes was designed to take into account Mobil1 is the oil of choice for many Corvette owners.
As a reminder, dealers are required to use Mobil 1 when performing oil changes on ALL 2014-2015 Corvettes through the Chevrolet Complete Care Program
Current reimbursement levels for Corvette are based on Mobil 1 usage. Please remind all personnel that only Mobil 1 should be used.
In addition, please refer to Global Connect message # G_0000205212 for details on dry sump equipped (Z51, Z52, and Z06) Corvettes.
The non-Z51 Stingrays also receive Mobil1 with the Dexos spec while under the Chevrolet Complete Care program.
The only difference is non-Z51 Stingrays do not receive the 500 mile break-in oil change
GM has changed the required maintenance schedule for all 2014/2015 Z51 and Z06 Corvettes equipped with dry sump systems.
The new schedule will require the oil/filter be changed immediately after the break-in period, which occurs after the first 500 miles of operation.
Once the break-in oil change is performed and the Oil Life Monitoring system is reset, customers should follow the Oil Life Monitoring system for all future oil change needs.
Tip: Only use Mobil 1 when performing an oil change on any Corvette under the Chevrolet Complete Care Program.
#596
Not surprised. Most dealers service departments are completely clueless. They will F with your car and break other stuff. I will not allow the dealer to do oil changes for the exact reason your mentioned. They do not read any tech bulletins, directives, or updates. GM could care less. "GM Trained" means "Beware: Untrained"
#597
Moderator
7 quarts is the specification for the NON dry sump (non Z51, non Z06)
#598
#599
Not sure i understand why folks want to spend $15 for the sole purpose of advertising for Exxon.
#600
Still see no reason to pay money to advertise for them. If they want to advertise on Corvettes, they should pay for the caps. Absolutely nothing wrong or worse looking about the cap that Chevrolet already provides. The replacement is not a dress up item, its advertisement.
