C7 ZO6 Brakes
C7 ZO6 Brakes
Hi there I have a 2015 ZO6 3LT that I just love BUT my brakes squeak at all stop light especially when braking slowly. This sucks when your driving a new $95000 car! Dealer thinks it will go away after 1000 miles I think he is wrong . Any new ZO6 owners experiencing this problem?
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
It's not just the Z06 that does it and there have been plenty of threads about Z51s doing it as well. Try searching for "brake squeal" and do a bit of reading
(cliff notes: dealer may not be able to fix it)
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Might even ask in the Z06 (not ZO6) forum.
The Consigliere
Received 5,443 Likes
If it doesn't go away, put some Carbotech 1521 brakes pads on it. I've run those on multiple vettes and have never had noise with them.
They also dust about 90% less than the stock pads (not counting the Z07 brakes which are different animals).
2015 ZO6 Squeaky Brakes
I started to get the same issue at 1000 miles on my 2015 ZO6! It happens when I am braking at 10mph-5mph to a stop light. Definitely embarrassing for a $97k car and now has 1238 miles on it...
Assuming you're past the initial 100 miles or so, do some hard stops will help but if you're usually easing to stops, brake squeaking is pretty common.
