Z06 Stage 1 Splitter - Painting it Carbon Flash!
Just food for thought, You never know… You may want to take this splitter off in certain situations. I travel a couple times a year for long trips and literally don't know where I'm actually staying or going, and the road conditions, so for my long trips it comes off. Unless your situation is locked in for the rest of the time you own a car , I would say don't use the tape because you may move to a new house,A new place to work etc. etc. Since the skirts don't have that situation, I screwed and taped them on because they're not coming off.
I took everyone's advice and took it down to Corvette World in Austin and they installed it for me for $60. Drilled holes (no tape). Not bad since I don't have a lift or jack. Here it is, plasti dipped, glossified (not sure if that's even a real word) and installed
Looks real good!
-M
-M
nice job - the splitter needs paint, in it's stock form, it looks cheap, the flash matches everything... - sorry my opin...
A few tips..
1.skip the 1500 sand and go straight to 3000 - you may have to sand a bit more to get surface uniform matte, but will gloss better..remember to get gloss you will need at least 100 strokes to bring it up. Keep going!
2.unitl you fully xpel, look for the 3/8 in door edge guard from xpel on amazon - tape on the leading edge after waiting 25 days and alcohol wipe first. I have 6000 miles on my painted splitter with not a single ding or mark.
3. next tine do 3 coats of clear - more coats than that makes it more brittle....
4. as long as you don't hit anything, you can touch up with the base coat and 205 anytime....get some artist paint brushes, spay some base in a cup and touch up - then repolish after 2 weeks (not right away)
A few tips..
Glen,
Sorry, I'm a newbie at this but I'm looking to do this as well, not only to the same splitter as this (which I may never get thanks to backorder), but also thought of doing it myself to the license plate mount (since here in the "wonderful" state of VA they require a front tag). I've never really painted anything before so I have many questions. But for now...what exactly do you mean 100 strokes (or 300-500)? Also, do you have a quick link to your thread on doing this?
Big thanks though to you and the OP for all the information you guys supply! Major help to DIYers such as myself!
Making progress..Was able to get the splitter wet sanded and polished...turned out very nice...all that is left is to install this weekend! I sure learned a lot in this process, my next painting projects will be even better... I feel pretty good that it turned out pretty good!
Here is the 3000 Grit sandpaper I used for the wet sand. I wet sanded until the gloss from the clear coat was gone.
Then I started polishing with the Meguiar's 105 cutting polish!
To finish up I then I polished with Meguiar's 205 polish and then a Blackfire Polish and seal, and finally Blackfire Crystal Seal.
Almost ready to be installed!!
Color match almost perfect with all other Carbon Flash trim on the car! Yay!!
-M
-M
Looks really good...I will probably end up replicating what you did as soon as the plasti dip I put on there starts deteriorating...Was one can of each of the paints enough? Did you have any dripping or imperfections from spray painting with cans?
this splitter will require:
2 light primer coats - and the first should be a VERY light coat..almost like you did not put one on, (adhesion promotor)
2 base color colts
2-3 clear coats
the secret is in the polish.....not the paint...
No issues with dripping or running. As Glen said, "keep it moving and learn to spray in spritzes - not lock the can valve open" that's the key. I also bought the spray handle for the cans, but did not use it this time.
-M
#35
I had my body shop paint mine it was $30 cost difference from DIY for the paints not considering my time and possible mess up LOL (Rudys auto body Orlando )
Rockers will be on in few weeks
#36
And here is the final result:
I don't have my jack yet so I used this contraption to drill the holes for the scrivets. Worked great. Easily got under the car.
Simple install.
Turned out pretty good! The combo of Z06 grille and stage 1 splitter really makes the front end look great
I sure learned a lot doing this project. Hopefully it helped others who want to do the same thing!
Next up: side skirt install next week!!
-M
Simple install.
-M
#38
About how much did it cost you all in? I will probably go the body shop route myself and then drop it off at the Xpel installer once done.
#39
Next time try laying down the final coat of clear quite wet. Just short of getting runs or sags. You'll have very little if any colorsanding to do.
I've painted many cars/bikes in my garage and that's been my experience. Autobody painter old saying: "If you don't get any runs you're not even trying." Or something like that.
#40
