Credit Union discounts ?
Are there certain credit unions that you need to belong to, to hopefully qualify for a discount on the 2015 C7 Stingray? Is the discount close or equal to the discount given as a GM employee -supplier ?
Thanks !
Thanks !
Yes, within each state there are certain credit unions. The CU discount is the same as Supplier.
I have found that you can use a USAA discount on any deal you make, including EE or Supplier discounts. At least I've done it with EE discounts, so I'd be very surprised if it did not work everywhere else too.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Thanks.
COL(Ret), US Army
Col (Ret), USA, Inf
It has been $750 for at least 6 or 7 years, and I've used that discount several times, each time for a new car. You only need to prove you have a USAA #, and you show them that or give them a copy when you buy. They simply reduce the money you owe by $750. I got an email from them that I have used repeatedly.
Col (Ret), USA, Inf
Col (Ret), USA, Inf
For January Macmulkin is offering 10% off msrp and no doc fees. That's better than supplier or credit union discount. I was ready to pull the trigger with them but then a local dealer with allocation matched the offer.
I hope MacMulkin is offering similar discounts in the spring so I can see if my local dealer (Criswell) will match them. Not saying I won't buy from Criswell over a few hundred bucks, but getting close to $1K, not sure.
St. Jude Donor '15
go to gmsupplierdiscount.com and you can find the list of credit unions that are accepted by GM. There are many in every state. Don't know if you have Randolf Brooks in your area, they are one of the bigger credit unions. You can add the USAA discount and if you have the GM credit card you can add that , also.
