Front plate holder
Each to his own; I like it better with the full Aeroplate. I seriously doubt that the small bracket on either side significantly affects air flow. You are suppose to take the entire bracket off (which would include the plate) when you track the car........to improve air flow.
Use the Aeroplate holder that came with the car. I personally do not like the looks of the "high mounted holder". If you want to use that holder I think I would paint it Laguna Blue. IMHO
Check your state laws for front license display. Some have minimum height requirements. Get an overzealous LE officer and you may wind up with a ticket.
Thank you Florida for no front plate requirement.
High mounted too ugly to bear
Yah, I agree with you. I'm gonna take it down, use the Aeroplate and take my chances with the Arlington and Alexandria LE.
Even if there is, as long as it's displayed, I highly doubt a cop is going to pull you over and measure it. The height difference between the nose wart and the aeroplate is very little, but the esthetic difference is gigantic.
Another thing to consider is that original plate holder is very likely scratching a line in the clear-coat at the top of the holder. The longer you leave it on there, the deeper the scratch will be.
Good idea. I bought a front plate bracket that was painted carbon flash. I may consider painting the aero bracket also. I have to see how it all looks with the stage 1 Z06 splitter installed next week. I may paint the aero and the splitter carbon flash. Of course we all know that the aero bracket per GM is not intended to be used as a license plate bracket.
Where did you get the front license plate frame that was already carbon flash metallic?
It is an atrocious assault and battery on the beauty of the car...
Please install the aeroplate and throw that pos in the trash!
I used 8" X 1.5" flat stock, that I bent at two different angles. I painted them black, then glued the plastic washers to the brackets. The license plate and frame, are both bent at 20 degrees, to match the angle of the nose of the car.
#38
Nice job. I am glad I started this thread, we have come up with some really good looking approaches. Those state that do not require two plates don't understand our plight. I don't need a ticket for missing a plate. Plus, I don't think it looks that bad if done correctly,
