Do You Have An Oil Separator?
Well, do you?
I saw a write up where a guy installed his and when I went to the website he mentioned the separator was $350
I think I paid 50 bucks for the one for my 2012 Mustang, I'm not sure if this is one of those "corvette tax" situations or what. It's a can that you put in the PCV line that collects oil, what makes them so expensive for the new LT1?
With all this foam talk and the possibility of problems with the dry sump engines, coupled with the fact that I think oil separators are generally a good idea, I figured I should get one on order for my new car. But I think that price is kinda excessive.
Yeah, mines a little spendy, it's a Stage 2 FI. Heard by many if you're running FI, it's a good idea. I am indifferent, but I'll take the better be safe than sorry route. Tons of opinions on this.
Moderator
You're kinda talking about two different things here. For the Z51 "burping" issue you need a "clean side separator". What you had on your Mustang was commonly called a "catch can". For $350 you can get a very nice machined aluminum catch can and clean side separator. You can get a catch can alone (again, machined aluminum) for $160.
I'll have to do more research for a clean side separator and see what that's all about. 160 for a separator with factory style lines isn't out of the question.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
I also purchased what is referred to as the "clean side oil separator" for $99 also from Elite. It provides added protection from oil coming out of the dry sump tank with the burped air. Both have filter material that collects oil vapor and condenses it into drops. These collect in the PCV "can" and fall back into the dry sump tank in the case of the "separator."
Supposedly GM says it isn't necessary however, the pictures here are of the oil found in mine after only 2000 miles. Seems excessive to me, I don't want this oil coating all the sensors and intake internals on it's way to the combustion chamber coating all the valves and combustion chamber once it gets there. You just can't convince me this is of no concern.
Seating the rings early is the key to avoiding that btw.
I have seen some new engines use a tremendous amount of oil then it completely goes away, just figured I would mention that so you didn't freak out too bad lol.
Ferrari and Porsche have had Direct Injection for several years and there are concerns shown for these cars. It was noted Ferrari was considering a special liquid cleaning solution be used on the intake at each oil change. There are documents showing the mechanical cleaning methods used by BMW to remove this baked on oil. Toyota even has an engine that adds port injection to a Direct Injection engine. The port injection operates periodically to clean the intake!
A quality "catch can" in the PCV system uses a medium to condense the oil mist into drops that collect in the can. Any amount collected is less passing the hot intake valves.
If you're tracking or adding a supercharger the issue is worse.
Just how bad a problem? We'll know in a few years!
Paraphrasing John Rydzewski, assistant chief engineer small block V8's in the December 2014 issue of Hot Rod Magazine:
" A PCV separator, which is unique to the LT4, was developed to keep oily air from being drawn through the intake, where it could end up collecting on the back of the intake valves. A little bit of oil on a port injected engine can help lubricate valves, but because all C7 V8's are direct injected, there's no fuel washing the back of the intake valve. That means oil in the PCV system can end up sticking to the back of the hot valves impeding airflow and eventually preventing the valves from seating properly."
There is no way GM wants oil from the PCV system passing over very hot intake valves in a DI engine!! There are some good pics if you search of what "coking" looks like in some other cars, not pretty!
One issue with "catch cans" is they have to be checked periodically, something many owners would not do! GM no doubt did what they could without added extra maintenance and that would meet Government standards. In addition a "catch can" is no doubt a help but is it the total solution, probably not. Manufactures try to use valve overlap to get some intake fuel to wash back onto the intake valve and other methods to mitigate the issues. However Ferrari, Porsche and others have good engineers and have had DI for more years than GM on high performance engines. They apparently have not fully solved the problem!
I had an issue with an oil smell at idle after the dealer changed the oil. I was hoping it was an accidental spill, but after several drives the smell lingers.
I am wondering if the catch can would somehow help with this or not. There was no oil in my intake though.
What is the general consensus on the best Oil Separator/Catch Can for the money?
This is a Z51 car by the way.
No way does GM think it's a good thing. It also effectively lowers the octane of your fuel which can lead to detonation, another reason the FI guys usually always run a can.
I think I will at least look at the Elite can, sounds like a reasonable price.
