4 door Z06?
4 door Z06?
2016 Cadillac CTS-V has the same motor as the Z06 but "down rated" to 600Hp (different exhaust and deep WET sump) no need for dry sump because hood clearance is not an issue
C7 type hood and side vents, dedicated all weather tires,
-PDR
-driver mode selector
-8 speed automatic
-optional carbon fiber pkg (rear spoiler etc.)
-0 to 60 3.7 seconds
AND an option that SHOULD be standard on the C7!!
SIDE MOUNTED cameras for curb view parking!
(protect those tires and wheels!!!)
-PDR
-8 speed automatic
Repost of a repost of a repost.
First it's 640hp directly from Cadillac's site, it weighs 600lbs more than the Z06, dry sump benefits oiling during high G turns and comes with the same Michelin SS tires as the Z51 which are summer only.
http://www.cadillac.com/v-series/2016-cts-v-sedan.html
CTS-V breathes power using a 6.2L supercharged V8 engine with 640 hp and 630 lb.-ft. of torque. It launches to a top speed of 200 mph on the racetrack and hits 60 mph in 3.7 seconds. The compact four-lobe Eaton® supercharger works hand in hand with Active Fuel Management®, providing pristine engine performance for everyday driving.
Base curb weight 4145lbs
CTS-V is stacked with six piston front and four piston rear Brembo® brakes, providing durability, consistency and the capability for track-day performance straight from the factory. Specifically designed and tuned for V-series, Michelin® Pilot® Super Sport summer-only tires2 deliver exceptional grip in performance driving situations. Simultaneously, they provide excellent ride quality and extended tread wear for everyday driving.
guess you know better then CAR & DRIVER with interview from GM engineer
see Feb issue, or do you work for FORD?
you REALLY think GM would let Cadillac quote a higher HP then Corvette?
tires are from a dedicated mold according to them
http://www.cadillac.com/v-series/2016-cts-v-sedan.html[/QUOTE]
http://www.caranddriver.com/features...rvette-feature
Read the article and get back to me. States the horsepower numbers that I quoted DIRECTLY from Cadillac's site. Where did you even get that 640hp is more than the Corvette? You must either be a simpleton or a troll.
And here is a picture of the "4 door Z06". I saw it at an Auto show over the weekend.
And here is the real thing.
