Anyone using a savvy to power a V1?
I use it and it works fine. You just need to get used to the detector turning on when you open the door as that's when power is sent to the ODBII port. I love the speed sensitive mute too.
If you need to get Onstar to run diagnostics just unplug it.
works great V1 goes off for everything in the world thought not impressed with the radar detector wish i got something else with less false alarms
only way to go plug and play set your speed and you don't hear those annoying false CVS stores still will see the lights no problem with onstar
Here's their FAQ on programming: http://www.valentine1.com/Lab/TechReport3.asp
Have it and love it. Great being able to program speeds to ignore. Blendmount; then run wire under headliner where it meets the windshield down the pillar molding and into the Savvy... easy as pie.
There are ways to help with the false alarms. First, use Logic mode, that will filter out about 50% of the automatic doors. Then, if you live in an area that doesn't use X-Band (most don't anymore) then turn that off, that will clear at least another 50% of the false alarms. Also, depending on when you bought it you may not have the latest crystal controlled oscillator. That helps narrow the Ka-Band to eliminate other things using the spectrum.
Yep, probably time for an upgrade, sounds like the oscillator has drifted which will exaggerate false alarms. Another thing the older units can't deal with are all the new collision avoidance, auto cruise and blind spot detection systems. I had to disable rear K band and add a 3 second delay to use my old one in my Jeep SRT because of the blind spot system.
Definitely get it upgraded. I haven't sent mine in yet, but they have a new "junk k fighter" update to help with those terrible new cars with collision avoidance.
I'd also recommend using the Yav1 app to help with falses and muting so you can lockout annoying signals. Now with auto lockout learning as well. Yav1 also has the ability to emulate Savvy among many other things.
How to Quiet a V1, Part 5: Savvy - YouTube
YaV1 2.0: GPS Autolockouts Explained - YouTube
V1connection, for Android for 49 bucks. Savvy is not really worth it for me as I rarely drive under the speed limit and don't want it plugged into my OBDII port.
BTW, I rarely use the V1 in my vette. I use it more in my daily driver as I commute between 2 homes 3 hours apart and it's all Highway.
Thanks for the videos on the YaV1. I just installed the app and waiting fr my V1 and V1connection for Android arrives. This is like Savvy plus a lot more. Awesome software!!
