C7 oil change
C7 oil change
A new mileage interval has been established for the first engine oil change on 2014-2015 Corvette Stingray models with the Z51 Performance Package and Z06 models. These vehicles are equipped with an engine featuring a dry sump oil system. The first oil change should take place at 500 miles (800 km) on these vehicles.
If the vehicle is driven continuously at a high engine speed with the first factory oil fill, silicone sealants in the engine’s gaskets may degrade the anti-foaming properties of the oil. This may lead to oil leaking out from the air cleaner assembly due to the oil foaming condition. The oil foam does not affect the engine’s durability, but changing the oil at 500 miles will help prevent oil foaming in the future because the silicone sealants are removed with the original oil.
Sounds familiar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
also will have rear end fluid level checked ....in the spring after a few hundred miles the oil will be changed again...oil is cheap ..
Dufox (09-15-2015)
my base C7 will be getting first oil change at about 500 miles ..then put away for the winter ... Mobile 1 5/30 and oem filter .... oil is cheap ..
Dufox (09-15-2015)
