Tire Rotation - yes or no?
Get a freaking alignment, people!
A proper alignment will solve all those problems. Cheaper and less likely to cause rim damage.
I've been slammed for doing it so often, but I have also gotten 68,000 miles out of a set of tires, so I just giggle at those who told me I was crazy.
Received 8,919 Likes
Bill
C6 tires were unidirectional and had a "rotation" arrow. C7 tires are bidirectional, but do have an "inside" and "outside." See Z51 tire pic below. I'm not inclined to cross axle rotate and reverse the direction of rotation. I've always been told that radials take a "set" and not to reverse rotation.
Ron
Ron
Bill
Michelin and GM spent a LOT of time and research building a tire specifically for the Corvette. I can't believe they didn't research tire rotation as part of their project. Say what you will about the manual and its quirks, if the manual says rotate then rotation is not only OK, its in the plan. Who knows more about your tires, you or the engineers who built them? I've had tires that wore in the "sawtooth" pattern and its damned annoying. I'll rotate to avoid the problem. Alignment is also important as has been posted. I always aligned my C4 myself, it isn't very hard to do with simple tools. I always got better tire wear than friends who didn't align or paid someone to align for them. ROTATE, my friends.
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
Since my main high "g" turn is a 270 degree off ramp and some of our rural roads are crowned, will consider swapping side to side at 5000 to 7000 miles. Did not do that on my C6 and the left side front tire was warn perhaps leaving 5000 miles more wear on the others.
Received 2,223 Likes
Switching side to side is just plain stupid. It's an error in the manual.
Assuming there are not any alignment problems I would think that the side-to-side flip would not make much difference in a street car. I'll see what mine look like when I hit the mileage recommendation.
St. Jude Donor '15
The tire manufacturers and GM have surely done a bit of homework on this issue. I think I will go with the manuals recommendation. As with any tire questions, I would search google and check with Discount tire or Tire rack. I know about geology, not about tires. So I will trust those that make their living selling tires.
#34
nope, not needed. As others have said, these are 20-25k tires. Rotating aint gonna change that. You need to understand, GM puts everything that they can think of in the owners manual that they "require" you to do to address any possible issue that may arise. This is a result of 1.) law suit happy people that are ignorant and say "you didn't tell me I had to change my oil and put gas in may car, and now its broke" 2.) so they can deny a claim to an ignorant person and say "yes we did".
Just because its written doesn't make it true.
#35
Received 3,288 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
#36
Received 1,974 Likes
Although I don't see much difference in tire wear after 12K miles...... I have my stock tires off and was just waxing the wheels this weekend....... on some cars I have seen the right side wear a little quicker then the left. I always thought this to be that there is more crap on the right side of the road, gravel uneven pavement and the like but just my theory.
Don't think I'd jack the car up just to change sides on the car but since I'll be pulling off my winter tires in a month or so will "rotate" the summer tires.
BTW no need to switch the TPMS ..... they will learn where they are as soon as you mount the tires or shortly there after.
#39
https://www.corvetteforum.com/forums...ere-s-how.html
BlueFinn (08-06-2018)
#40
