Ranger Quick Jack System
Old 02-26-2015, 09:01 PM
tractman
tractman's Avatar
Default Ranger Quick Jack System
Anyone on this Forum using this Ranger Quick Jack System.....I'm looking for something like this and after watching the videos I'm really interested. Just wondering if anyone has any experience with this product. Thanks in advance for your help.
http://www.bendpak.com/Shop-Equipment/QuickJack/
Old 02-26-2015, 09:16 PM
DocHolliday
Support Corvetteforum!
DocHolliday's Avatar
I'm interested as well, this looks great.
Old 02-26-2015, 09:22 PM
SevenTurns
SevenTurns's Avatar
St. Jude Donor '13-'14-'15-'16
Would be a nice solution without being permanent. Prices ?
Old 02-27-2015, 02:13 AM
///ADMAN
///ADMAN's Avatar
I like the lock bars.
Old 02-27-2015, 07:02 AM
macdaddy548
macdaddy548's Avatar
I like the concept a lot. But wonder if / how it would align to the C7 jack points / pucks. Anyone see a price?
Old 02-27-2015, 08:40 AM
tractman
tractman's Avatar
Here are photos of a C7 on this lift....I haven't found the price yet....looks like I'll need to write or call for the price. I was hoping that someone here already was using this jack.
http://www.bendpak.com/QuickJack-BL-...s-Corvette.pdf
Old 02-27-2015, 09:03 AM
Chuck Mahnke
Chuck Mahnke's Avatar
This link should answer most of your questions:
https://www.corvetteforum.com/forums...bl-5000-a.html
I've used mine several times and it works great.
Old 02-27-2015, 09:10 AM
11B250
11B250's Avatar
bout 1300 for the corvette one which supposedly lines up perfect with c7s
Old 02-27-2015, 11:40 AM
Rave
Rave's Avatar
I'm seriously considering this jack too. Two questions for those that own one. Each lift mechanism looks to be fairly narrow and there's no cross bracing between the two lifts; how solid is the lateral stability? And do the quick disconnect fittings leak?
Old 02-27-2015, 05:33 PM
Chuck Mahnke
I have the BL-5000. It is 11" wide and is very stable. The quick fittings do not leak once they are connected. I keep a small shop towel under the fitting when I connect or disconnect as there will always be a small amount of fluid that comes out of the connector when working with them.
Also, the included rubber pads line up perfectly with the jack pads attached to the car.
Old 02-27-2015, 05:38 PM
Harris
Harris's Avatar
Same here, at first look it appears too light but it works great. If you are just doing small jobs, tires, brakes, detailing etc I think you will be happy with one of these units.
Old 02-27-2015, 05:41 PM
macdaddy548
Thanks for that info. Anyone think a group buy is possible?
Old 02-27-2015, 06:41 PM
chimazo
chimazo's Avatar
I bought my BL-5000 about 2mo ago and it is great. I haven't had a chance to put my Z/28 up on it yet because my wife cracked up her Beetle backing out of the garage, so that's been up on it for a few wks while I sourced parts. It is very sturdy and I wouldn't hesitate to work under it. Unlike the C6/C7 (and for those who may use them their other vehicles), the Beetle and the Z/28 have pinch welds as their lifting points, and the supplied rubber blocks hold up to them fine without any adapters needed.
Old 02-27-2015, 07:59 PM
Rave
Rave's Avatar
Thanks Chuck. That's what I needed to know.
I contacted the company about the possibility of a Group Buy Discount. Unfortunately the answer was no. Bummer...
I plan to order one in April or May.
Old 02-27-2015, 08:00 PM
tractman
tractman's Avatar
Thanks for your comments....I will be pursuing one of these.
Old 02-27-2015, 08:36 PM
DocHolliday
A group buy would have been great, too bad. Really interested in one of these - I need to measure my car and see that it will fit under the skirts with it lowered all the way on stock bolts.
Old 03-01-2015, 10:42 AM
cheapthrills
cheapthrills's Avatar
For a tad bit more get a real lift
http://www.costco.com/.product.11731..._0226_AutoSolo
To Ranger Quick Jack System
Old 03-01-2015, 11:52 AM
Rave
Rave's Avatar
Originally Posted by cheapthrills
If I were in the market for a real lift I'd get the one below. Watch the videos to see quality differences:
http://www.backyard-buddy.com/videos.html
The advantage I see to the QuickJack, it's easy to store it out of the way.
2-pole lifts can have their problems. Here's one example of one of the two poles giving way:
Old 03-02-2015, 07:38 PM
chimazo
chimazo's Avatar
I thought about one of these, but then you're getting close to the cost of a full-size lift, plus $2k vs $1300 is a decent difference in price, and you have to drill holes in your floor (and make sure you have adequate thickness) for the MaxJax. My garage actually has a very high ceiling, but even when considering a used full-size 4-post lift, I had to add the cost of getting it to my house, assembly, electrical (if it needed 220v), and raising my garage door runners and lift. I also planned on buying a really nice low extended floor jack ($300) to replace my ****** aluminum Craftsman, but got the BL-5000 instead.
What really sealed the QuickJack for me was that if/when I get a full-size 4-post lift, I can still use the QuickJack to get the car in the air (up off the ramps) instead of buying a couple pricey bridge jacks.
Old 03-09-2015, 02:15 PM
EVL-C8
EVL-C8's Avatar
Once locked in position can the cables be disconnected for storage? Re-connect cables and lower when ready to move car again?
I'm thinking of using this outside under a carport for winter storage allowing me to remove and bring the wheels and tires inside?
Would that work?
Quick Reply: Ranger Quick Jack System
