Too tall for a C7??
Too tall for a C7??
Recently visited a dealer to look at the Z06's. I was very disappointed to find that I don't seem to fit in the car due to lack of headroom. I am not some giant at 6'3", but my head hits the top in both the hardtop and convertible. The only way I could drive these was with my head tilted to the side! I can't believe that GM would design the C7 so limited as to discount tall owners.
I have owned my C6 since new for several years, and obviously fit in it. Any others with this experience?
Are there alternative seat options that allow taller driver's to fit? I had the seat all the way down and reclined as far as it would go in the C7.
Are you sure the seat was all the way down? I am 6' 3" and have no problems. I found that if you move the seat forward a little you might find that it goes lower.
At least 5'9 1/2....no problems
seat adjustment
Good luck with "search", I never can find anything. That said, recently someone had a very nice discussion about, lowering the seat, pushing it forward some, then tilting the seat back. Seems to me that the writer of that post was at least 6'4" maybe taller and he claimed to have over an inch of headroom after the adjustment. I'm 6'2" and I'm fine. Work with the seat some, I bet you can make it work.
Good Luck,
bill
Good Luck,
bill
Im 6'4 280lbs and I fit in the Z06 fine. I just picked up mine on Saturday and drove it from NH to NY with no problems. My head does not hit the top and my legs are comfortable considering I have an M7.
I used the seat trick to fit...
Have it go forward all the way first with seat back forward as well. Then make the base of the seat go all the way down. Then shift the seat all the way back and have the back recline. Simple...Some also bring the seat forward a little and arch the bottom up a little them let the back recline a little more. It does work!
Good luck!
Good luck!
Good luck!
Good luck!
Disconnect the two wire connector on the wall behind the seat, under the carpet.
Here's a thread on it:
https://www.corvetteforum.com/forums...-question.html
E-Ray, 3LZ, ZER, LIFT
Received 9,605 Likes
Good luck!
Good luck!
When I enter and it moves to my driving position it feels a bit unusual to have the seat dip and move that far forward.
Same here...... 6'4" fit is roughly similar to my '07 Z06 in terms of headroom.
If you are very long in the upper body I could see you having some issues. My friend is 6'5" , so one inch taller then I am but he needs 3 to 4 inches more in headroom because of the length of his legs compared to mine. So just like many of the other posters have stated I think you should go back and try to seat positions again.
good luck....don't miss out.
6' 4" and I am fine with the headroom. I could use a bit more legroom though (36" inseam).
I would recommend that you relax and spend 10+ minutes in the car trying to get it dialed in for you. The transparent top and competition seats might give you a bit more headroom, just FYI.
Being 6'4", I didn't have any head troubles in the coupe, but did have troubles getting in and out. The wheel didn't tilt up enough nor go in enough, thereby my thighs hitting/rubbing under the wheel every time I tried getting in & out. No problems with this in my C6. Yes, the seat was all the way down and back, as I lived/tested this car for a week as a rental in Orlando.
