Rear Wheel Horsepower
In general, the rear wheel dyno numbers posted here for C7s have been in the range of say 400HP/410 torque to maybe 415/420.
I find it interesting that the April 2015 issue of Car & Driver has two articles that address a 2015 Chevy SS which has a 6 liter LS series engine rated at 415HP/x? torque. C&D said that the car had 299HP/299 ft lbs at the rear wheels.
Of course I don’t know what type of dyno was used but being 100+ down on HP compared to the C7 is interesting. Don
Driveline loss is "generally" between 14-17%. The claimed numbers are definitely pretty low. The article is either not reporting accurate information, or there is significant parasitic drain somewhere. I suspect the former.
Funny, I've always heard and read that as a general rule, 15% is the number most frequently used and recognized as appropriate....perhaps 1or 2% higher for some automatic transmission vehicles, and 1 or 2% lower for some with manual transmissions.
here is a stock SS dynoing for a baseline... made 359whp
2014 Chevrolet SS - Baseline Dyno Testing at Hennessey Performance - YouTube
Dyno numbers tend to be all over the place. I think the usual correction factor is 15% for a manual transmission and more for an automatic.
The only real value for these tests is for when you are making changes to the car so that you can see if it is helping or not. But even that is suspect, since it is not unusual to see gains over the first run on subsequent runs without making any changes. Is that the car "learning" its' tune, lubricants warming up, or the dyno itself?
Maybe that Chevy SS cited was grossly out of tune, like some people suspected that the Z06 was when compared to the GTR at Willow Springs.
If you can always count on dyno numbers, then I have one of the world's most powerful stock LS6's.
Go Canes!
I don’t know why I didn’t think of it before but that 299 HP number sounds just about right taking 17% off of the 361 HP rating of the G8GT with the 6 speed auto, the only transmission available that year, our second car.
Sounds like perhaps C&D grabbed the wrong dyno number? Don
Dynos vary a lot as well. That is a big gap though.
