Mods Finally Done
Mods Finally Done
2015 C7 Z51 M7, removed stingray and Corvette emblems, visor warning stickers gone, added z06 grill, z06 steering wheel, Braille light weight battery, Spiegler s/s brake lines, high conductivity spark plug wires, AR mid length headers, Halltech carbon cai, B & B bullets with speedway black tips, Carbotech 1521 pads, MGW shifter, deleted NPP valves and pulled fuse #42, added GT sound mat.
Lost 50 lbs net in weight, gained 40 hp.
Now I have to wait for the snow to go.
Where does the net lose of 50 lbs come from? The light weight battery is really that much lighter? Or does the exhaust swap save some too. Do you have a breakdown in where the weight savings comes from? Thanks!
How about dollar and time investment figures?
The Braille battery is 21 lbs vs. 39 for the stock. The headers are about 25 lbs lighter, z06 grill little lighter then stock, exhaust about 10 lbs., carbon cai is about 10 lbs lighter, added weight sideskirts, 12 lbs, GT sound mat 4 lbs. The figures are approximate but fairly close.
Dollar in CAN $, exhaust $1725 install $200, Halltech carbon cai with install $1650, ss brake lines with install $300, z06 wheel $345 install $100, z06 grill $350, I installed, plug wires $200, install $50, Sideskirts $730 I installed, Carbotech brakes $425, install $200, removal of badges $0, 20 minutes of rubbing with goo gone, battery $330, I installed. Time for what I did about 6 hours, mechanics time total 12 hours
Got it from my dealer, New Roads Chev in Newmarket. It took 2 months. I think the list price was $727, They did me a favour with the pricing. I had to find a z06 and get the vin # otherwise they had difficulty with the part as it didn't match my c7 vin.
Hate those stickers!!! Paper towels folded to the size of the stickers and soak it with rubbing alcohol. Place the paper towel on saran wrap and tape it to the visor so the paper towel is in contact with the sticker and the saran wrap holds it in place. Tape around the edges of the saran wrap (which should be slightly larger the folded towels) and let sit for 30 min. I didn't take the visor off. Remove the paper towel and the sticker should peel off. There will be a slight residue left on the visor. I just left this as it is not too bad, but you can try goo gone and rub it until the residue comes off. I didn't do this so as not to damage the visor.
