Where is the OBDII port located?
I can't find the OBDII connection that is usually under the dash? I want to hook up my DashHawk and see if it reads the A/F ratios. Doesn't on my G8's, but I have Innovate wide band sensors in headers on both so I know A/F.
Thanks!
We found it when looking in the daylight. Last night I didn't have a flashlight and the courtesy light was blinding me. Knew it had to be under there somewhere.
Unfortunately, there is no A/F reading on my DashHawk, so assume the only way to get that is to do an Innovate wide band bung or similar. Have all the other readings I see on other GM cars.
Received 4,682 Likes
