Head Up display not "sticky"
I have several GM cars with the Head Up display, including a C6. All of them return to the last setting when you restart the car. My C6 Z06 does not. I have it set to a display that shows the RPM and G Force. When I turn off the car and restart it the Head Up display shows the first screen with speed only.
Is this normal? If so, I don't like it and GM needs to get it back to the way it works with the C6.
Head Up dieplay not "sticky"
Originally Posted by Glen e
the HUD is part of the "display" - when you "unlink to driving mode" in settings, it will remain where you want it...
Received 4,684 Likes
I believe you meant to say "My C7 Z06 does not". Otherwise, this is in the wrong section of the Forum.
I will try unlinking the drive mode. If that is true, I still thing GM messed that up. No matter what drive mode I am in, linked or not, the Head Up display should remain at the setting I left it.
I unlinked the driving mode and the Head Up display stays where you left it. As I mentioned in my previous post, I don't like the way that works. No matter what driving mode I am in when I set the Head Up display it should stay where I set it unless I change it.
I sure don't understand their logic on this one,
Moderator
