Gas question
Old 03-25-2015, 11:08 AM
magneto10
Support Corvetteforum!
magneto10's Avatar
Default Gas question
Choices
1.) Pure gas- 91 Octane (no ethanol)
2.) 93 Octane (with 10% ethanol)
Both are available from "TopTier" gas locations
Old 03-25-2015, 12:20 PM
Bill B 1
Bill B 1's Avatar
All other things being equal I will always chose non-ethanol. But with the octane dif. I don't know....probably still go with non-e just out of general principles.
Old 03-25-2015, 12:38 PM
BIG Dave
BIG Dave's Avatar
Received 4,682 Likes on 1,862 Posts
1. Probably no 'Seat Of The Pants' difference between 91 and 93
2. Probably no long term consequences of using 91 or 93 octane fuel
3. Probably the savings of using 91 octane won't amount to a hill of beans
So probably, none of it matters. Just do what makes you feel better. (For the record, I use 93).
And I should probably limit my use of the word "probably".
Old 03-25-2015, 12:41 PM
DAFFYDRUNK
DAFFYDRUNK's Avatar
Still waiting for my C7 to ship but my other unmodified cars seem to like 91 non ethanol better. Maybe the 93 Ethanol would be better if you get a tuner and to the 93 octane tune.
Old 03-25-2015, 12:45 PM
GOLD72
GOLD72's Avatar
Received 1,101 Likes on 715 Posts
Given a choice, I would generally pick the higher octane. However, if your car is a garage queen, ethanol does absorb water over time and I would thus think the non-ethanol blend would keep longer without the addition of a fuel stabilizer.
Old 03-25-2015, 01:11 PM
mkr1966
mkr1966's Avatar
Why would anybody use ethanol if they they didn't have to if non-ethanol was available?
Old 03-25-2015, 03:00 PM
dvilin
dvilin's Avatar
Received 7,918 Likes on 4,804 Posts
Old 03-25-2015, 03:20 PM
HIHO
HIHO's Avatar
Today's engines are designed to operate with ethanol based fuels.
By design, I mean all seals, gaskets, hoses or other rubber or plastics that the fuel comes in contact with are ethanol compatible.
Older engines may not be so lucky.
Ethanol will cause non-compatible rubber and plastics to swell, craze or crack. So it is important when replacing these components to make sure they are compatible with ethanol.
Ethanol burns cleaner and is more EPA friendly. Ethanol replaced MTBE which was a carcinagen.
Old 03-25-2015, 03:52 PM
4thC4at60
4thC4at60's Avatar
Received 2,886 Likes on 1,294 Posts
Old 03-25-2015, 04:08 PM
mkr1966
mkr1966's Avatar
Also less BTU per unit of measure than gasoline. EPA friendly? I don't care.
Old 03-26-2015, 11:34 AM
magneto10
magneto10's Avatar
Different octane ratings-
If there was 93 or 94 pure gas near me I would go with that- unfortunately best I can do nearby is the 91
Or go with 93/94 with ethanol.
Old 03-26-2015, 12:12 PM
Bill B 1
Bill B 1's Avatar
More EPA friendly......when all factors are considered that is a debatable statement.
Old 03-26-2015, 12:15 PM
Glen e
Glen e's Avatar
I can get non-eth too but it's more expensive than 93 ethanol. So 93 eth it is. In a closed system like in a car, eth is fine to burn unless you are looking for 1/10's of diff in seconds at the drags.
DD here, don't care that much to use Eth....
To Gas question
Quick Reply: Gas question
