Battery voltage in tour display
Just wondering if 12.6 to 12.8 volts was normal. I would have expected an alternator readout of around 14 volts. I'm assuming it is reading, as implied, the voltage of the battery.
That's good to hear. I thought that I'd seen it at higher volts before so that makes sense. I had taken a 4 hour drive with 6 or more stops and when I returned and put the 'Ray on the charger it took many hours to "go green", so when I saw it at 12.6 volts I was concerned. Especially after hearing of some battery failures in new C7's here.
I too have been concerned about the much higher level of charge from the supplied charger as compared to the system. And that is because of occasional slow crank mine does. But no warnings from the car have appeared, or any of the auto shutdowns to non-essential items have occurred!
