Stoptech Big Brake Kits are finally available
Supporting Vendor
Front kits use StopTech ST60 6 piston calipers.
Rear kits use ST41 4 piston calipers.
2 piece front rotors are 380 x 32mm
2 piece rear rotors are 355 x 32mm and have an integral parking brake.
The front rotors/pads are a new 'wide annulus' design which provides a larger friction surface and more pad mass. The swept depth in front increases from 51 mm to 60 mm. This should be near 20% more pad mass over the ST60 pad which is already much larger than your OEM pads.
That is a big increase in brake pad material and will spread the heat load over more area.
Black and Red Kits are IN STOCK.
Front Kits:
Rear Kits - With the integrated park brake drum as well.
The wait is finally over - Stoptech has released the C7 Kits.
Big 380mm front rotors with a new wider annulus rotor and 355 mm rear rotors.
We'll be looking for a taller pad from Carbotech and probably Ferodo to take advantage and the rear pad is CHEAP for the ST41 caliper in race friction. Seems like they actually thought about what they were doing.
Pretty sure that's enough heat mass to handle lots of laps.
We're getting a few sets in stock so we can see actual parts - and if you want one of those you will be rewarded. We're ordering red and black - front and rear car sets. Want a trophy or other color - call now and get that introductory deal.
These don't sell every day of course - usually it's a few weeks to make/get together etc. We want to buy w/ OUR money and then sell to you. That's our job.
All of the kit details are here - I'll spare CF the bandwidth.
http://www.stoptech.com/media-center...rolet-corvette
-Ken
-Ken
Supporting Vendor
Pricing is released
Front slotted kits - red or black $3695
Rear slotted kits - red or black $2895
Zinc/drilled rotors/other colors = additional charges
Trophy kits are also available as well.
Front = Retail $4445.00
Rear = Retail $3645.00
-Ken
-Ken
Supporting Vendor
Stoptech kits are 2 piece rotors w/ AL hats and iron rings made in the USA.
AL calipers - in this case they are the ST60 6 piston version.
380 x 32 mm curved vane rotors
Wider annulus pads. We are confirming info on that. The regular ST60 calipers use a 51mm pad.
They can be configured to suit your needs i.e. max float hardware etc.
We ordered 4 front and 2 rear kits - red and black.
Email me at ken@knsbrakes.com if you would like to get an order started.
Do you have any install instructions for the C7?
