Fuel smell after fill up
Old 03-29-2015, 05:55 PM
qictrk
Support Corvetteforum!
qictrk's Avatar
Default Fuel smell after fill up
Garage smelled like someone poured gasoline all over the floor when I went inside after fill up from previous day. I saw that someone else had a similar problem. Was there a fix put out by GM? Cecil...........
Old 03-29-2015, 06:27 PM
grandpawmoses
grandpawmoses's Avatar
Possibly you are overfilling?
Old 03-29-2015, 09:24 PM
crawfish333
crawfish333's Avatar
CI 6-7 & 9 Veteran
I think there is a recall out there for the gas tank filler hose, but "topping off" might cause that as well, especially in warm climates.
Old 03-29-2015, 11:08 PM
ArcticC7
ArcticC7's Avatar
It's a recall. Time to see Mr. good wrench.
Old 03-29-2015, 11:25 PM
Old Yellow
Old Yellow's Avatar
The recall is for the anti siphon grid, inside the filler hose, slipping out of place, and possibly falling into the left side tank. That wont cause a fuel leak, or fuel odor.
However there is a TSB for a possible fuel leak in the high pressure fuel line located under the intake manifold. Best to have the dealer check it out. If one would catch fire, or enough are discovered leaking that may justify a recall.
Ed
Old 03-29-2015, 11:29 PM
qictrk
qictrk's Avatar
I will give a call tomorrow morning. I only have 150 miles on it and I was going to wait, but this could turn bad quick. Thanks, Cecil...........
To Fuel smell after fill up
Quick Reply: Fuel smell after fill up
