Track Mode - What is this gauge and why does it never move?
Received 4,682 Likes
When in Track Mode, the bottom right gauge never moves, stays at 100. What is this gauge? It appears the other three are Oil Pressure, Oil Temp and Voltage. (I checked Chapter 5 of the Owner's Manual and didn't see an explanation.)
Thank you
Thank you
Thanks guys! That explains it, my commute to work is only 11 miles and takes me only 15 - 20 minutes. That explains why the gauge doesn't move.
I am assuming that screen is your instrument cluster and not part of the HUD??? I went out to my car ( 2015 A8 coupe 2LT) and tried to find that display with no success. How did you get to that screen and are those horizontal circles across the top of the screen "shift lights".
And here I thought I knew the car pretty well ......not so much.
Thanks, Doug.
you have to hit the left arrow on wheel ,go to settings ,seclect, r. arrow to display then r. arrow and pick sport .now back track to pref.hit seclect ......................or just go to you tube and its there. i posted it awhile back .....good luck.
theres also away to set it to change from the seclect ****, for each mode your in .
I am beginning to realize there is a whole bunch of other stuff and display options I am not aware of. Maybe some day a tech guy will do a u-tube video of all the displays the car is capable of
Thanks again, Doug.
Also ,very cool display on the instrument cluster. Previously with a bit of "spirited driving " coming on to the interstate form the acceleration lane I had used the paddle shifters and noticed as I approached the top of the RPM range a horizontal band of lights illuminating under a different cluster display. On the cluster you have shown me how to get into I see now what I had been looking at.
Thanks again, Doug.
Thanks again, Doug.
Thanks again, Doug.
Received 1,295 Likes
Look up in the Sticky Threads section. There are several items on DIC menu and gauges in this section:
https://www.corvetteforum.com/forums...cking-etc.html
Ron
Ron
