Now Available at SCP - C7 Corvette Z06 ACS Side Rocker Skirts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
2015 C7 Corvette ACS Z06 Side Rocker Skirts
All New ACS Side Rockers for Corvette Z06
-- OEM Quality for a Third of the Price of GM Part! –
It is our pleasure to introduce our new Z06 side rockers. Our rockers are a replica of the Aero3 side rockers and yet ours will only set you back a third of the price of the originals. Not content with providing incredibly competitive pricing, we’ve actually ensured that our side rockers will offer an advantage over their GM counterparts, we have extended the under carriage section to fully protect the OEM painted rocker section.
So, as well as improving the aerodynamic performance of your vehicle, our rockers will protect some of your precious paintwork. As is standard with ACS parts, the Z06 size rockers come fully prepped and primed – smoothly moulded and finished with a precision and finesse that truly stands out. The design is cleverly tailored to suit the wider body of the model and adds zest to what is already a spicy ride.
The manufacturing of our side rockers is designed with simplicity in mind, ensuring that installation can be completed in a mere 30 minutes, using the mechanical fastener kit supplied and avoiding the use of messy adhesives or double-sided tape.
The following features come as standard
- Manufactured in an OEM-validated RTM composite material
- Will enhance your car’s aerodynamic attributes at high speeds
- Will not lower the ride height of the vehicle
- Contoured profile for easy access
- Smooth finish to both sides that exudes class and facilitates easy cleaning
- Mounted to the original OEM rocker panel
- Protects OM painted rocker panel
- Installation kit
- Road Guard protective coating sprayed on inner surfaces for longevity and show finish
Available Finishes
- Black Primer with undercoating paint on inner surface
- Satin Black Finish with undercoating paint on inner surface
- Carbon Flash Finish with undercoating paint on inner surface
Available Here: http://www.southerncarparts.com/c7-c...ts-p-7298.html
- Installation kit
Available Finishes
As a non-mechanical person I have what might be a dumb question. Do I need to put the car on a lift or race ramps to install these or can they be installed on the ground?
Thanks.
Thanks.
I think ACS has the cheapest prices for aftermarket side skirts currently. The fitment on these parts are precise. I have the Z07 ACS rockers.
Do they fit the non-ZO6 C7?
Is there anything to worry about when drilling into the rocker panel on a z51, cooling lines or anything that could go seriously wrong?
Supporting Vendor
Supporting Vendor
Thanks,
Dave
Do we know yet if these will fit the Grand Sport? Also, which is the correct splitter to match?
