Winter Storage ?
Old 04-04-2015, 02:12 PM
JDM111er
JDM111er's Avatar
Default Winter Storage ?
Just got my Vette out of winter storage and it runs and looks great. Thanks to Glen and everyone else for your assistance
The only challenge I have is my gas measurement isn't working. When I put it into storage, I had near a full tank. Now it's just stuck on a little over an eighth of a tank. And no leaks. Does anyone have any suggestions? Thanks in advance.
Old 04-04-2015, 02:15 PM
Thunder22
Thunder22's Avatar
Received 2,311 Likes on 1,456 Posts
Put a bottle of techron in the tank and run the car (don't run out of gas). If it doesn't clean up the sending unit, you're probably going to have to take it to the dealer for service.
FKING1
FKING1's Avatar
Might try Techron (sp?).
My C5 and others, had gas gage problem that it corrected.
Old 04-04-2015, 03:08 PM
JDM111er
JDM111er's Avatar
Thank you. I'll try the Techron
Old 04-04-2015, 10:24 PM
JCar
JCar's Avatar
Hope you are using Sta-bil or similar in the tank when you go to store.....
Old 04-04-2015, 11:22 PM
JDM111er
JDM111er's Avatar
I did
Old 04-04-2015, 11:24 PM
JDM111er
JDM111er's Avatar
I used the Techron. How quickly should it work?
Old 04-05-2015, 06:46 AM
Thunder22
Thunder22's Avatar
Did you drive the car? How many miles?
If that doesn't work, my other thought was to disconnect/reconnect the battery.
Old 04-05-2015, 08:14 AM
Larry/car
Larry/car's Avatar
It might take a tank or even two. Your float is probably stuck and/or potentiometer is contaminated and needs time for deposits to dissolve. Warranty?
Old 04-05-2015, 09:02 AM
JDM111er
JDM111er's Avatar
It's a 2014 and will be a year old in June. Thanks for the suggestions
Old 04-05-2015, 09:04 AM
JDM111er
JDM111er's Avatar
So I should add more gas?
Old 04-05-2015, 09:16 AM
Larry/car
Larry/car's Avatar
Watch your mileage, so you don't run out. I would get the fuel level down to about 1/2 tank to cycle the potentiometer. A few times will tell if the indicating system will start working. My car was built on April 18th, can't believe almost a year has past.
Old 04-05-2015, 09:50 AM
JDM111er
JDM111er's Avatar
I've put about 25 miles on it this year. It appears after driving a little that my gas gauge shows a little more gas in the tank. I'll estimate driving to half a tank and go from there. Thank you
Old 04-06-2015, 09:34 AM
JDM111er
JDM111er's Avatar
I drove it until I had approximately half a tank of gas. I filled up with gas and my gas gauge says I'm on empty now. I have an appointment to be serviced later this week.
To Winter Storage ?
Quick Reply: Winter Storage ?
