Weird seat memory recall issue....
The memory function on my '15 Z51 2LT seat/steering wheel settings has been working fine until today...I adjusted the seat settings slightly before I left for work and now when I go to start the car the memory settings don't engage. Nothing happens. When I hit the memory 1 button, the steering wheel moves a millimeter and then I keep having to hit the 1 button 20 times before all the settings are set. Sometimes holding the 1 button down will force the setting to completion.
I have read a couple of posts about making sure that the seats are not beyond their "limits", but that does not seem to be the issue.
I was thinking of "rebooting" the seat memory by pulling the appropriate fuse, or just "rebooting" the entire car by disconnecting the battery....and if that does not work, a trip to the dealer...
Any additional ideas?
Thanks in advance.
-M
Thanks in advance.
-M
Moderator
Did your "I adjusted the seat settings slightly" including setting the exit position further back? Or perhaps, tilting the seat more backwards? If so, you are probably hitting the rear bulkhead limit switch. Adjust your exit position so that your seat does not touch any part of the bulkhead behind the seat and see if that fixes your problem.
Thanks for the advice!
-M
Thanks in advance.
-M
Thanks in advance.
-M
Mine will go to the memory settings if I hold down the memory 1 button after starting the car, and goes into the exit position fine once shut off.
I've been meaning to take it back to the dealer but haven't found time yet.
If I find anything out, I will post here.
Wow, this is kind of eerie - mine began doing exactly the same thing a couple of days ago. Switching fobs didn't help. Tonight I found out that when in the exit position, my seat was all the way back. I moved the seat forward about a half inch and reset the new position as the exit position. Problem solved.
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
Mine has been doing the exact same thing. I took it to dealer and they had it for 3 days, only to get it back with them giving me printed instructions and telling me there wasn't anything wrong.
For whatever reason, for an M7 trans, whoever programed the seat memory in the C7 decided not to follow what worked great in the C6, i.e. one touch of the seat memory and the seat and wheel go into the memorized position. Instead, unless you start the car and with a standard shift that means depressing the clutch, which for many of us means the seat must be forward, you have to hold in the memory button!
I speculated (jokingly, but perhaps not) that they outsourced the software overseas and the person never drove a car! This is reinforced by the option of having the seat move forward when you open the door and with the patch devised in late 2014, which appears to me that person did not provide the proper source code because this alternate method is not like the C6, you have to hit the Start Key twice! Some folks like this “alternate method” but in the 1 ½ years since I have had my C7, M7 I have used a two hand multitask approach! While pulling the seat belt over to buckle with my right hand I push and hold my memory button with a finger on my left hand. Then depress the clutch and push the Start Button only once. Quicker way too start and it is easier to reach the belt to buckle when the seat is in the rear position. Works for me.
In October 2013 my dealer had no idea what the problem was and I credit the forum for defining the irrationality! Perhaps this info is a help for new 2015, M7 owners.
Just a couple days ago it started happening again. I haven't changed any settings.
I hope it goes away again like it did last year. I will try mpuzach tip now. Thanks.
I just have got in the habit of moving the seat slightly forward after exiting. That moves the seat away from the sensors and everthing is fine. You also have the option of setting the memory to engage at door opening or start. Just fun quirks about the car that you learn to adapt to.
From manual:
Thanks in advance.
-M
Thanks in advance.
-M
Thanks in advance.
-M
Thanks in advance.
-M
I hope this works for you.
I started with recall problem today after it worked fine for 2 days after delivery. I tried both FOBs still no go. I moved the seat up just a touch and reset the exit. Now everything working great again.
I tried the info in Cute Ginger's YouTube video. It worked great. You have to turn off the auto seat function in the settings, then set the seat memory, then turn the auto seat recall back on. The memory seat position has to be at least 1/2 inch from back wall.
If unlike the OP, yours always did the same thing and you have a standard shift, as GM likes to say, it is working as designed!
Seriously, how hard can it be to: Get in the car, push the clutch in, start the car and the seat/steering wheel/mirrors move to their correct position. No question if this is the worst thing that happens to me, I'm golden....it's just a dumb way to have to use a "memory" function.
Jimmy
Like you, I've gotten used to the "2 hand" method (seatbelt with left, holding memory "1" with right). For the life of me, I cannot understand why the car (M7) cannot be programed to return to the "driving" memory settings when you start the car. I am sure there's some stupid lawyer/safety reason why this can't be done, but I'll be dammed if I can think of it (my car has had the late 2014 seat "re-flash" which, IMO, was a waste of time). Seriously, how hard can it be to: Get in the car, push the clutch in, start the car and the seat/steering wheel/mirrors move to their correct position. No question if this is the worst thing that happens to me, I'm golden....it's just a dumb way to have to use a "memory" function. Jimmy
Jimmy
Jimmy
I agree the attempt to patch the issue with the alternate software was not what I thought was a “fix” so I didn’t bother, although some folks like it; to each his own.
Jerry
