QuickJack 5000 Experiences
Anyone have experience with this, good or bad? Stability? Usability?
http://www.quickjack.com/products/qu...-capacity.html
They have pics on their website showing a C7. So it appears to be low enough to drive over it, and matches up with the correct lift points.
Wow that is a must have!!!
Affordable, quick, easy, portable. Their video even shows how it is perfect lift system for a C7, comes with the necessary pad/puck to keep from damaging the rocker panels.
I dont see any negatives.
Thanks for the link!
got one. used it several times. works great.
ditto about the steel safety bar. if you are concerned, you could always use the lift to raise the car up, put jackstands under it, and lower it onto the jackstands. still much easier that jacking up each corner of the car.
also, one you have used it, I think you will trust it.
if you are in the Chicago area, pm me and you can come over to see mine.
