Camaro getting LT1 now?
This picture came out today. Is this what I think it is?
Source: http://www.chevrolet.com/2016-camaro/
Historically, Camaro always got engines from Corvette. Last couple of times I remember was 2008 Corvette LS3 showing up in 2010 Camaro. And then recently the Z/28 with LS7 engine from C6-Z06.
So, is this the LT1 engine going to Camaro? Yes, de-tuned and all that, but if so, isn't it too early for the king's engine being borrowed?
Detuned, no, but the camaro usually has a smaller hp number than the corvette counterpart with the same engine. LS3 Corvette 436 Camaro 426
I have a 2013 Camaro 2SS/RS 1LE and it is definitely a bad boy...517 rwhp.
GM has already announced both the Camaro and Cadillac are going to get the same 8 speed auto as the C7.
Don't know what the Corvette has to fear. C7 I'm sure weighs less.
Nothing wrong with a little sibling rivalry
The Camaro will never be "more" of a car than the Corvette. You don't have to worry about that.
Well, technically it IS more of a car.. like 400-800 pounds more. Gonna need a LOT more than the same engine to make up for that discrepancy.
GM may not advertise Camaro HP higher than Corvette but they will make sure it is competitive with the Mustang.
Can you tell the difference between 420 and 450 horsepower?
Probably not.
2015 mustang 0-60 4.4 sec
2015 corvette 0-60 3.8 sec
2015 camaro ZL1 (same msrp as the vette) 3.9 sec
The weight different is the factors that affects it the most I would think.
The new CEO has made one comment. "No more crappy cars"........ all brands and model lines are now supposed to be the very best they can be.
GM will not likely do anything to protect a perceived "king".....fact is you've already seen a Camaro that had development ideas that matched that of the best Corvettes in the Z/28.
The OLD thinking no longer applies. Clearly GM wants all of it's cars at the highest potential they can achieve....... if the Camaro team of engineers gets uncomfortably close to the Corvette.......that's the Corvette designer's problem to overcome.
Competition is no longer just between brands....... it now happens between models under the same brand at GM.
Corvette still enjoys a substantial advantage anyway. A higher price point and the two seat design makes for what is just about certain to always be the lighter car and that higher price point allows for the use of more expensive......well..... what-ever it takes to make the car go, turn and stop.
But engine sharing shouldn't surprise you at all in this new environment where the only rule from above is, "No more crappy cars!"
Since the 6.2 truck already makes 420 I'd bet the Camaro will have more. My guess is 450hp 460 torque and 27-28 mpg hiway 8 speed auto 7 speed manual. SS will probably be in the 3650 lbs range. V6 probably about the same with a bump in mpg maybe 31 hiway. Don't care about a 4 banger but I'm sure we'll see one.
SS>GT
1LE>GT track pack
Z28> GT350
650hp ZL1 = GT500. Both will be much better track cars than the Hell Cat but slower 1/4miles times.
SS>GT
1LE>GT track pack
Z28> GT350
SS>GT
1LE>GT track pack
Z28> GT350
SS>GT
1LE>GT track pack
Z28> GT350
