Which gear should I use to go uphill
I live on a hill. The road to my house has a 25mph limit, and when I drive up to my house, I'm usually traveling at 30mph on 3rd gear. When I get to my driveway, I can smell the car burning, presumably the clutch. Should I be going slower? maybe use 2nd gear instead? What's the best way to go uphill at this speed so I'm not hurting the car?
In my other car, the Hyundai Genesis coupe v6, I would start out on 3rd gear at 30mph, then half way up I would loose momentum and get to 2nd gear, but then I'd be traveling at 15mph and the car doesn't smell. But my other car has only 300hp. I figure the Vette has so much torque that it wouldn't be a problem and I wouldn't have to go 15mph anymore...
1st
That burning smell won't be the clutch simply because you are going up hill. Unless ur slipping the clutch otherwise, going up hill, even if not in the ideal gear will not burn the clutch.
Like said above use first. Max 2nd.
Your clutch should not be "burning" unless you are riding the peddle on the way up the hill. Simply use a gear low enough to keep the engine from laboring. Hard to believe 3rd would be a problem.
With the available torque the C7 has in manual or auto tranny; unless you live on top of Pikes Peak I'm pretty sure you should be able to go up and down the hill without too many problems. Smelling something burnt unless as said several times above, that you may be slipping the clutch is a problem.
Sounds like someone should have gotten an A8.
You clutch should not be "burning" unless you are riding it. If your foot is off the pedal and the clutch smells like it is burning then something is wrong, take it to dealer for service.
If the engine is not lugging badly or stalling then the gear you are in should be fine.
I'd say 2nd should be fine at that speed, no need to drop to 1st.
Hell I can start my car from a dead stop in 3rd gear with no issues, this engine has tons of torque.
I live over the top of a very steep hill which has a slow 90deg turn/intersection at the very bottom. I run this hill in 3rd @ around 30 mph or less all the time. A burning smell is not a good thing, you should have it checked out.
Unless you're driving straight up a cliff the car will be fine in 3rd. If it smells, there is either a problem with the car or the as already mentioned you need to get your foot off the clutch. If the car is new it may just smell. The first week I had it my car smelled a little like burning chemicals when driven into my garage while fully warmed up.
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
If hill is steeper than 30 degrees may need an inclinometer!
Of course, we don't know how steep the hill is ... but if you're getting a 'burning' smell, you're doing something wrong and may have already damaged the clutch.
In general, under a load like that, keeping the RPMs around 1800 or so should provide plenty of torque .. pick a gear that gets you there.
But get your clutch checked out .. and never touch the clutch unless you're changing gears .. keep your foot off at all other times.
Personally, I use 7th gear for everything.
Should've got an automatic
Received 2,225 Likes
