Does NoviStretch Mask Burnish Clearcoat?
Curious if the NoviStretch Front end bra burnishes the clearcoat. Guessing that anything that comes in contact like that with the cars surface would longer term with the inevitable road grim and micro-movement. Wondering what NoviStretch users have experienced....
I do not use it daily only when I take a long trip...aI've probably done 3000 miles and the novi has not affected the paint. when traveling, it comes off every night and is washed in the sink. And put on the next morning.
The Novistretch mask is very porous. It does and will catch small debris like sand, road grit, bugs, etc, although the mask fits tightly across the front of the car so there's little if any chance of this caught debris would rub the finish. Of course always best to remove and clean it regularly.
I had mine on for the 1600 mi trip from FL to IA... Does a great job protecting the paint with no burnishing/scratching issues.
When I'm not using it on my car, I wear it to contain my man *****.
Great dual purpose bra!!!
St. Jude Donor '15
I have used mine on longer road trips, a variety of road conditions and have had no problems with marring the paint. Rain and sun it worked fine. I found that by pulling out down and away from the surface insures that you won't cause any damage from the grit that gets trapped near the bottom of the bra. It does a nice job of protecting the finish. And for a little extra insurance I add a coat of wax, polish or sealant. Which ever I have closet to hand before I put the bra on.
