Tried to program new FOB, now I can't start car!
Old 05-28-2015, 03:19 PM
daveshea
daveshea's Avatar
Default Tried to program new FOB, now I can't start car!
I need help with a serious problem. I purchased a new key FOB, and programmed it to the car using the instructions in the owners manual for programming when an existing FOB is present. While the doors will now lock and unlock with both key FOBs, I cannot start the car, period.
Regardless of which FOB I use, whether I place it into the steering column slot or not, etc., I cannot start the car.
I tried to start the procedure for programming the FOBs when a working FOB is not present, and I do not get any message on the dashboard at all after doing the "key turn 5 times" thing in the trunk lock.
Now, it appears not only can I not program any key FOBs at all, I can't start the car at all to even take it somewhere for help.
What am I doing wrong? I need help reprogramming this mess or at least starting the car so I can get help!
-David
Old 05-28-2015, 03:22 PM
rmorin1249
rmorin1249's Avatar
Received 1,738 Likes on 1,174 Posts
St. Jude Donor '15-'16,'18
Man, I wish I could help. I would be freaking out but I guess a flatbed to dealer is an option.
Old 05-28-2015, 03:24 PM
daveshea
daveshea's Avatar
The car is in my garage and I can't even seem to find a way to get the car into neutral to back it out for a tow truck!
Old 05-28-2015, 03:36 PM
RicK T
RicK T's Avatar
Maybe you didn't press the "unlock" button to finish the procedure?
Anyway, read through this step by step programming to see if you missed something:
http://www.ls2.com/boggs/c7/C7RKEProgramming.pdf
Old 05-28-2015, 03:47 PM
speedlink
speedlink's Avatar
Old 05-28-2015, 04:35 PM
aj98
aj98's Avatar
Perhaps your timing on the 5 times in 5 seconds is not quite right and that's why no message.
For example, my 05 trailblazer has a similar sequence to reset the oil monitor light, but if I press too fast, it ignored/doesn't accept the input; I have to repeat the process until I get it right.
Old 05-28-2015, 05:34 PM
Drh
Drh's Avatar
Same thing happen to me. I disconnected/reconnected the battery and all was back to normal.
DanInFlorida (05-21-2019)
Old 05-28-2015, 08:54 PM
daveshea
daveshea's Avatar
I figured out the issue. I think I sort of locked up the relearn process by accident. Leaving the car and coming back about 10 mins later, the car would start. Then, as long as I put all key FOBs inside the house, I was able to put it into the relearn procedure and accomplish what I originally wanted: to erase any old keys and all just the two I have.
Success! I guess the system timed out after 10 mins or so and let me try again.
Old 05-28-2015, 10:01 PM
xp800
xp800's Avatar
Glad you got it figured out!
In the future, if you need to shift the auto into neutral without starting the car...
You need to get the car into service mode:
  1. Foot OFF the brake
  2. Press and HOLD Start button for ~8-10 seconds
  3. Lights and chimes will sound and it will be just like the "old days" of key two clicks forward in the On/Run position
  4. Release Start button
  5. Press brake and shift into Neutral
  6. When done, move back to Park and press Start (no foot on brake) to get out of the service mode (if you don't do this the car will stay on until the battery runs out)
Regular Accessory mode is almost the same, but just press and release Start without foot on the brake.
Old 05-28-2015, 11:54 PM
C2C3C4C6
Support Corvetteforum!
C2C3C4C6's Avatar
When you think about it, what was wrong with just using ignition keys?
Old 05-29-2015, 08:47 AM
Corgidog1
Corgidog1's Avatar
Received 2,523 Likes on 1,482 Posts
I would either call dealer to have someone walk you through the steps or maybe chevy service to walk you through the steps.
Old 05-29-2015, 08:59 AM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes on 2,058 Posts
2015 C7 of the Year Finalist
He allowed too much time between steps and the car timed out. He did it correctly and he does not have a problem now and the RKEs operate just fine.
Elmer
Old 05-29-2015, 09:00 AM
eboggs_jkvl
I spent a lot of time on the link in post #4. Read it, follow it EXACTLY and RKEs can be programmed as advertised.
Elmer
To Tried to program new FOB, now I can't start car!
Quick Reply: Tried to program new FOB, now I can't start car!
