Carbo tech pad fitment
I bought Carbo Tech 1512 pads and they fit like sh*t..
I had to go to a shop and have them ground and tampered to fit.
Anybody else have this issue?
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
On the front pads after I got the old pads out (not easy) I did have to clean the residual tape from the pistons. Apparently commonly used in Europe to reduce noise, the high temp tape was not used on 2015's.
Installed a set of 1521's on my Z51. Rear brakes made clicking & clacking when brakes were pressed and released. Took measurements and compared to stock pads they were not to original specs. Returned for full refund and CarboTech confirmed the they were not to specs.
When I slid my new carbo techs into the caliper they were a little wide and it was a tight fit. It would make it real hard to get them back out when it was time to swap them. It looked like the pad material was offset from the backing plate slightly. I just ground down the edge a few thousands on a bench grinder and they slid right in. I am swapping pads often between my track pads and street 1521's so easy removal is key for me.
Installed two sets of 1521s - one set in my Z51 and another set in my buddy's Z51. Not a problem in either install. Pads were slightly thinner than OEM and although the original pads only had ~ 1k on each set. Slid right into place. Both sets made some very minor squeal in the first usage, but went silent immediately thereafter. No issues since with about 300+ miles on them. Very reduced dusting as promised. Great stopping that is hard to differentiate from stock, but my sense is slightly better modulation.
Jeff
Jeff
