Leaking lumbar ??
Old 06-04-2015, 02:18 AM
chipsvette06
chipsvette06's Avatar
Default Leaking lumbar ??
When I pump up the lumbar bladder with the seat control the lumbar support seems to only stay at the set level for a few minutes and then deflates to the point that it was before I increased it.
Is that the same for everyone or do I have a leak?
Old 06-04-2015, 07:42 AM
agapsdiver
agapsdiver's Avatar
Mine lasts between 5 to 8 hours with air.
Old 06-04-2015, 08:01 AM
rcooper
rcooper's Avatar
St. Jude Donor '15
You have a leak, time to visit your dealer.
Old 06-04-2015, 09:11 AM
Ernest_T
Ernest_T's Avatar
Lumbar support is pneumatic?
Old 06-04-2015, 09:36 AM
billeee
billeee's Avatar
Mine also deflates. I haven't been on any long trips to see exactly how long it takes, but I have to pump it up if I leave it overnight. This is not rocket science. It should go for months.
Old 06-04-2015, 10:58 AM
b4i4getit
b4i4getit's Avatar
They probably had a bad batch of bladders at the seat factory. Should be easy for the dealer to replace. Just make sure they put the seat cover on tightly to prevent sagging.
Old 06-04-2015, 11:12 AM
Bill B 1
Bill B 1's Avatar
same question. I thought they were all mechanical. Mine stays where I put it, always, even after the long winters nap in my garage.
Old 06-04-2015, 11:17 AM
Ernest_T
Ernest_T's Avatar
The owners manual doesn't give any hint that the lumbar is pneumatic.
SteveSoCal
SteveSoCal's Avatar
Yes, like some past "girlfriends".
Old 06-04-2015, 11:19 AM
b4i4getit
b4i4getit's Avatar
Too much information.
Old 06-04-2015, 11:29 AM
Ernest_T
Ernest_T's Avatar
Where does the compressed air come from?
Old 06-05-2015, 10:14 AM
billeee
billeee's Avatar
Small electric air pump built into the seat.
To Leaking lumbar ??
Quick Reply: Leaking lumbar ??
