Fuel Capacity
Fuel Capacity
What is the fuel tank capacity of the C7?
http://www.chevrolet.com/corvette-st...ecs/trims.html
Stingray = 18.5 gallons
Fuel Efficiency section
Don't run out!
For the record, during the factory tour I was warned never to let it run out of fuel. Reason: Fuel pump(s) are in the tank(s) and will rapidly burn themselves out absent fuel to cool them. As one who has the bad habit of letting fuel get low, I took the advice to heart.
red-vette-ragtop (03-27-2024)
Keithwinnfl (07-27-2020)
St. Jude Donor '09
In the C6, and I assume the C7, the "gas tank" is actually two 9-gal. fuel cells, one on either side of the torque tube tunnel behind the driver and passenger, connected together with a flex pipe over the tunnel.
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
Wonder if everyone knows you can download a PDF and use a word search. In fact just Googled 'fuel capacity C7 Corvette" and the top link had the info.
Moderator
