So, I finally tried Eco mode.
#41
I feel this slight jerk or uncomfortable quick "pull" a lot as well. To the point that it has gotten annoying. Does anyone else have this - typically when keeping the accelerator depressed at an even amount (not going up or down hills)?
When I bring up the mileage display, there is no correlation between the switch to V4 and V8 and the jerking sensation. There is also no correlation with the load on the car or the speed I am travelling (usually only happens above 20 mph).
It is very subtle though, as my passenger had no idea it was happening.
I've been stubborn and never put my M7 Z51 in Eco mode. After all, I didn't buy a 460HP V8 to save gas and diddle around. That and I'm a bit uneasy with half the cylinders getting less/more wear than the others. I'm sure that's naive thinking, but...
That said, after 3.5 months and 4500 miles I decided I should see if Eco mode was functioning properly. I have to say I was pretty impressed with the integration. Aside from a slight jerk when entering v-4 mode the system is seamless. When you need the power she goes back to all cylinders firing nearly instantaneously. Maybe I'll actually use it now.
#44
I wish the driver could choose to disable it at will with the flip of a switch. If our government wasn't always forcing more regulations of dubious value down our throats this country would be a better place. So are all the Corvettes on the road that are equipped with cylinder deactivation going to make a real difference in pollutant levels and conservation of fossil fuels? What were the esteemed members of Congress who brought this regulation to fruition thinking? It's one more thing adding complexity and possible problems down the road. It amazes me that people get all excited over a few more miles per gallon.
#45
I expect to achieve better gas mileage than my 2001 C5 with a 6 speed and the HP going from 350 to 460 horses
#49
If I cared about economy I would have bought a Prius. But, then, I would be ashamed to be seen in it. Maybe GM has something...a Z06 that masquerades as a Prius? Or is that just a Prius Poser?
#50
#52
2. Congress did mandate fuel economy standards, and frankly that's a good thing. We'd be importing even more middle eastern fuel otherwise.
3. In terms of the entire auto fleet, 1 mpg makes a huge difference in the amount of fuel used. While a couple of mpg may not matter to you, it has a huge impact on the U.S. economy and geopolitical balance of power.
4. There was an article published about the time the C7 was introduced that said GM basically had a choice between AFM or automatic start / stop to be able to meet fuel economy standards and still produce the power we all love. AFM is probably the least objectionable of those two options. If you really don't like it, buy a manual.
tlippy (04-21-2017)
#53
I may be one of the rare ones but I leave it in eco mode a lot of the time but I have adjusted the engine sound management so the exhaust it open all of the time. The exhaust sound is probably one of the only reasons I put it into sport mode.
I've only had the Corvette for a couple weeks but I've never been in a situation where eco mode wouldn't allow me to pass someone or get the acceleration I need. I'll never use the full 465hp (but I do like that it's there) on the street so why not save a few MPG?
I DID buy the C7 because it is capable of 30mpg, I love how it looks, and I like to be seen in it. Not so I can race a Dodge Neon with a fart can on the highway.
Just my $0.02.
Just my $0.02.
#54
1 Off
2 Auto (mode selector)
What does each option do?
#55
Also, found this info on another board:
"Off will leave the flaps open all the time...mostly. There are still the flaps forward of the mufflers that do stuff mostly in 4-cyl mode. I leave mine in the off (open) all the time. I also notice that on some up shifts, I can hear something is closed until about 1700RPM the valves open. The driver mode does not affect this behavior, all modes behave the same in the 'off' position. "
#58
To my ears (someone please correct me if I'm wrong), in OFF, the exhaust is open all of the time and doesnt open/close based on what driving mode you are in. In AUTO, it opens/closes based on what driving mode you are in (ie. Eco, it'll always be closed. Track, it'll always be open).
See post 252 (and 248 for more detail) here:
https://www.corvetteforum.com/forums...post1589760867
#60
Not completely accurate. In no mode are the valves at the rear open all the time. Even in track mode, or off, the valves close partially in 4th and 5th gear below about 36 mph in order to pass federal noise standards. In 4th gear, that's 1700 rpm, in 5th gear 1200 rpm. This has nothing to do with AFM mode, as it happens even if you put the automatic in manual mode, and on the 7 speed in all modes.
I didn't know there were actually regulations on it. Feds just can't ever let us have any fun!
